The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > trying to compound for the first time...
      02-21-2012, 05:09 PM   #1
jm3as
267
Drives: 2007 e92 328i
using ultimate compound from megs. tested a 2x2" section, found it almost IMPOSSIBLE to remove after heavy heavy rubbing to get it off the car. is this normal? i dont have that issue with wax?!
also, the compound doesn't seem abrasive enough, i've got a ton of swirl marks from the previous owner that i want to get rid of. any suggestions?
facebook.com/jmeasphotography | jmeas.4ormat.com | IG: jmeasphotography
      02-21-2012, 06:47 PM   #2
jm3as
267
ah so its the pad that causes this to react and stick to the paint? i used a microfiber pad cover
      02-22-2012, 01:02 AM   #3
3_runner
3_runner's Avatar
Drives: 328xi
Question: You didn't let the compound dry, right?
      02-22-2012, 06:12 AM   #4
lopealle
Resident Black Guy
lopealle's Avatar
Zimbabwe
251
Drives: Lion
2006 M5  [10.00]
If you want you an come by place and i can show you. Im only 20-30 minutes from you.
Did you wash and clay the car?
      02-22-2012, 10:19 AM   #5
jm3as
267
nope i tried wiping it off literally after i'm done doing a small section.
      02-22-2012, 10:21 AM   #6
jm3as
267
yea it was washed and clayed. i think i found the root of my problem though. My buddy who does detailing said i shouldn't be using a microfiber bonnet on the orbital, but it should be a actual pad instead.
the bonnet he told me, was used for wax after the fact. any confirmation on that? i'm pretty sure he's right on this one.
i'll give it another go, if i run into the same issue, i'll swing by your spot! thanks!
      02-22-2012, 01:22 PM   #7
lopealle
Resident Black Guy
lopealle's Avatar
Zimbabwe
251
Drives: Lion
2006 M5  [10.00]
I have personally never used a bonnet. I have only used a pad. I will let the pros chime in on that one.
      02-22-2012, 02:06 PM   #8
3_runner
3_runner's Avatar
Drives: 328xi
Well in that case, no it is not normal. I know it can be a pain doing it by hand but it can be done. If the compound feels like its about to dry, add more compound and rub off. Maybe there was something wrong with the bottle.
