Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Headlight Cleaning Solution?
      02-17-2012, 03:22 PM   #1
D-Raw
Drives: 335is
So over time my headlights are getting blurry, it looks like dust or something thats built up and i cant seem to clean them off with soap or towels and it disappears but when it is dry it comes back again. Is there any product that i can use to get rid of this? or do i have to polish it out
      02-20-2012, 08:05 AM   #2
D-Raw
Drives: 335is
Bump
      02-20-2012, 08:41 AM   #3
fibonacci
Fancy Member
Drives: 2007 335i
Wetsand them. Basically you start with a medium-grit wetsand with some soapy water and work to finer and finer grit. Then polish after you're sanding at the finest grit.
      02-20-2012, 09:03 AM   #4
D-Raw
Drives: 335is
Have you done this before?
      02-20-2012, 12:04 PM   #5
JDLM
JDLM's Avatar
73
Drives: 2009 335i Sedan
toothpaste
      02-20-2012, 12:52 PM   #6
D-Raw
Drives: 335is
Thanks you guys I will try some of those out
      02-20-2012, 04:41 PM   #7
Miami
these cars become an addiction :/
Miami's Avatar
13
Drives: 08' E92 328i
Originally Posted by JDLM View Post
toothpaste
Originally Posted by I M STIG View Post
9-tenths of a second is a hell of a lot of time!!! That's walking all over the AMG. In fact, not only is that walking all over it, that's finishing, jumping out of the car, shitting in your own hand and throwing it at the AMG as it drives by to finish its lap.
      02-21-2012, 07:56 PM   #8
dukecityevo
Drives: M4
I use Meguiar's PlastX It's a clear plastic cleaner and polish. Picked it up at Pep Boys.
      02-22-2012, 09:14 AM   #9
D-Raw
Drives: 335is
Is it just cloth applied or it has to be polished ?
      02-22-2012, 05:20 PM   #10
dukecityevo
Drives: M4
cloth applied. apply small section at a time then wipe with a clean cloth
      02-26-2012, 07:20 PM   #11
ppatel223
31
Drives: F10 I3.0
Use superfine WET sandpapers, it is cheap and easy!
      02-26-2012, 08:11 PM   #12
dluke
Sh!t happens... Deal with it
dluke's Avatar
Drives: '06 Alpine 330i
'06 BMW 330i  [0.00]
cheapest and easiest way is WD-40.. just spray some on a paper towel and wipe em down.. i know is sounds strange but trust me it works great. all those headlight restore products are are basically a silicone lubricant which fills in all the micro-abrasions that are making the lens look fogging, in turn making it look clear again. which the wd-40 does basically the same thing.. i just used in on my dads bmw's headlights and as soon as i finished in was like 'shit i should have taken some before and after pics'. but anyways try it out, you'll be very surprised
      02-26-2012, 08:31 PM   #13
Otruba_843
Otruba_843's Avatar
93
Drives: 2009 E90
random orbit buffer and some flitz polish. Expensive but it works. You can pick it up at you local boating improvement store. Works really well.
      02-26-2012, 09:36 PM   #14
FloridaGatorsChomp
10
Drives: 2006 330i
Angry
Originally Posted by Revelation19 View Post
Get yourself a DA random orbital buffer and try using Meguiars M105 Ultra Cut Compound. And/or M205. Takes less than 5 minutes to buff out the headlight haze. After polishing, seal with a good sealant.
These are good products to use on your paint too.
Why are you using affiliate links? I see you have been doing this in other treads as well and is against the rules on this forum!
Last edited by FloridaGatorsChomp; 02-26-2012 at 09:43 PM.. Reason: Found in other threads as well
      02-26-2012, 09:44 PM   #15
JDLM
JDLM's Avatar
73
Originally Posted by Miami View Post
You have doubts?
      02-27-2012, 09:18 PM   #16
D-Raw
Drives: 335is
Where can I purchase the wd-40?
      02-27-2012, 09:44 PM   #17
Miami
Miami's Avatar
13
this isnt a permanent fix, it will just fill in! as soon as it rains the product will just run off and youll be back to hazy headlights. the only permanent solution is to wetsand and polish (hopefully with a machine)
      02-27-2012, 10:50 PM   #18
csupernova
csupernova's Avatar
32
Drives: E90 330i
3M headlight restore kit and lots of patient. my headlight looks like NEW again!!!
      03-01-2012, 08:46 AM   #19
D-Raw
Drives: 335is
Can someone post a short DIY on wet sanding or give me a list of all the products I will need to finish the job
      03-06-2012, 12:41 PM   #20
vapore0n
40
Drives: 2010 335i
You have doubts?
I use tooth paste for polishing jewelry. Works great too. Would have never though of using it for this.
Ill try toothpaste on my gf's car. She needs those headlights cleaned up.
      03-07-2012, 07:45 AM   #21
droptop335
39
Drives: '07 335i (E93)
Before going through a lot of work like wetsanding, give klasse all in one a shot, or any other cleaner/sealant product. It may be all you need. If it doesn't give you the results you're wanting, you can always wetsand.
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD
By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word.
      03-09-2012, 10:28 PM   #22
Foreman05
18
Drives: in search of a 335
Here's what I did last fall
http://www.e90post.com/forums/showthread.php?t=599106
