What Tyre Pressures for these non-RFTyres
02-16-2012, 06:55 AM | #1 |
Rep 41
My E92 325i MSport had 18" wheels on when I bought it but I opted for 4 x new 19" Cades Tyrus staggered Mesh cross spoke alloys - 19"x8.5" et38 front and 19"x9.5" et35 rear plus 2 x new 235/35/19 and 2 x 265/30/19 Nankang sport NS-2 tyres.
I know the tyres are not the last word in sophistication, but, that apart, what tyre pressures should I use for running alone or with one passenger - does anyone know? |
02-16-2012, 07:06 AM | #2 |
244
Rep 7,690
Drives: 335i SE Coupe Space Grey
about 40 psi maybe.
02-16-2012, 08:37 AM | #3 |
1545
Rep 8,972
Your door plate will cover 19" sizes too (part or fully loaded), I see you're a tad wider than OE, but just start with those pressures and see what you think.
02-16-2012, 10:06 AM | #4 |
Rep 41
Must be honest that I'm writing this from my sick bed (man flu) but presumed that the door plate would be for run flats and that they would need a different pressure?
02-16-2012, 10:43 AM | #5 |
227
Rep 1,489
what are the nankangs like mate?
im switching at the end of the month (pay day!) and i wondered how much difference the extra money between them and falkens would give me. |
02-16-2012, 11:20 AM | #6 |
118
Rep 2,216
Drives: E91 330d M Sport
They are, but that doesn't mean non-RFT pressures will be different. Use that as a starting point and see how you go - I run 1 or 2 psi over RFT pressure and it works about right for me
Just how many Yorkshire sheep can you fit inside one exhaust?
02-16-2012, 11:35 AM | #7 |
Rep 41
To be honest, I suspect the Falkens would perform better under test conditions but I don't drive the car balls out as I have the TVR for that kind of experience. They haven't given me any nasty moments and the £1020 for the set of four wheels and tyres, balanced, delivered, locking wheel set and set of wheel bolts was all I could really justify on top of the cost of the new car.
02-17-2012, 02:23 AM | #8 | |
227
Rep 1,489
liking the motor by the way, dont see many that colour, wheels look good too. |
02-17-2012, 02:30 AM | #9 |
43
Rep 487
assume they're from mark at bmautosport? got my old lm style wheels from him in 19s
he reports good things about nankangs - similar to what you say to answer your q - the door sills should give you an idea but... i was always told as bmws are RWD you should inflate the rear a tad more than the fronts (as the car rocks back when accelerating) so i kept my staggered 19s at 34 front and 36 rear but then i noticed wear on the inner aspect of the tyre (but that maybe the camber on the rears) i suspect 32 front and 34 rear maybe better. try both and see how it feels? love both the cars btw |
02-17-2012, 02:43 AM | #10 | |
1545
Rep 8,972
BMW probaly spent millions testing tyre pressures, so 5 minutes chat in the pub car park probably won't come up with a better idea OP - yes, standard pressures are for RFT, but as said start there and see how you get on. Pressures are primarily related to tyre width and vehicle weight, neither of which changes when you go to Non RFT. |
02-17-2012, 02:48 AM | #11 |
1545
Rep 8,972
02-17-2012, 03:13 AM | #12 |
43
Rep 487
fair enough
but FWD/AWD don't rock as much (due to the physics of the movement) hence the reason for bmw as you say increasing the rears otherwise they would recommend all 4 the same like other companies the door sills provide a range also so once you;ve converted the bar to psi you'll find the pressures i've suggested fall within that range ... i think ... |
02-17-2012, 04:03 AM | #13 | |||||
Rep 41
If you're referring to the TVR, I shouldn't think there's another one in that colour to be honest. It's a long story but I specced it at the factory in Red Bull Blue pearl and it looked great when pristine clean but when slightly dirty the blue merged with the black highlights (front headlamps, air intakes, windows and rear lights) and it looked a bit "dead". So, after 12 months, as there were a few small paint defects and because several new features had been developed for the car since its launch, TVR were (then) happy to take back to the factory, check it over, upgrade it with all the latest parts (e.g. new dash, new luggage cover, etc) and look at fixing the paint defects. I cheekily put a note in complimenting the factory guys on building a great product and asking if it would be possible, whilst trying to sort the defects, to respray the car in a different colour. They called after 10 days to apologise for it taking so long and consequently they agreed to change colours but I only had that evening to decide what to go for and as it had a Prussian Blue dash top, Portland Grey elsewhere, Navy carpets piped in Portland, Charcoal Lamonta inserts, I needed to find someting light that matched the interior. At the time silver cars were two-a-penny so I opted for this which was a Vauxhall colour called Space Green. You see it occassionally on old Corsas. It was a full, glass, doors, bonnet out job with primer, 4 colour coats, 5 of clear laquer so not cheap for them (but all free for me!). Wheels are standard TVR 18" alloys, known as "spiders". Quote:
Thanks for all your suggestions, kind comments and help guys. Last edited by Snakes; 02-17-2012 at 04:54 AM.. |
02-17-2012, 04:19 AM | #14 | |
118
Rep 2,216
Go back to your high school science lessons and try again
02-17-2012, 05:43 AM | #15 | |
1545
Rep 8,972
The rear weight transfer under acceleration (in any road car) is minimal, adding passengers or loading the boot will have much more effect, and that's the same for any car. But anyway, the rating plate is good reference point to start with. |
02-17-2012, 05:47 AM | #16 | |
1545
Rep 8,972
Hmmm jealous buddy! |
02-17-2012, 06:24 AM | #17 |
Rep 41
I presume you are looking on PistonHeads? That seems to be the place as there is such a strong TVR presence on the whole site. I would just be wary of an early (2003/4) car that hasn't had an engine rebuild as it almost certainly will need one at some time.
I promise you, it will be the most rewarding car you'll ever buy as long as you don't listen to the pub bar bores (or Top Gear for that matter) and you go into ownership with your eyes open. TVR owners are a really friendly and supportive bunch so if you need any guidance or help to select a car just ask. Someone will jump in their car or get on the phone and offer to get stuck in. Email me if you need anything. |
02-17-2012, 08:25 AM | #18 | |
Rep 41
