      02-06-2012, 06:55 PM   #1
Todd
27
Drives: 2020 M2
Tire upgrade for stock 1M wheels
I would like to upgrade the tires on my 1M to Michelin Pilot Super Sports and retain the factory wheels. I am thinking 255 or 265/35/19 fronts and 275/35/19 rears. Can anyone provide any input what larger tire sizes have been used with the factory 19x 9 & 10 wheels ?
      02-06-2012, 11:08 PM   #2
///M1
///M1's Avatar
273
Drives: Many
FYI: 265/35/19s up front will rub (top of fender liner), stay with 255/35
You can check Tirerack as far as dimensions and proper available sets that'll fit, the rear 10s can do 295/30 (as 285 is not available in the PSSs).
Use this to see how your speedometer reading will change once you move from stock sizing
http://www.miata.net/garage/tirecalc.html
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      02-07-2012, 01:29 AM   #3
Todd
27
Drives: 2020 M2
Does a 255 / 295 setup require spacers front or rear ?
      02-07-2012, 07:19 AM   #4
Fundahl
Drives: VO 1M, 300zx TT
You can get 265/30 for the front in PSS. Not sure if it will rub though.
265/30r19 F and 295/30r19 R sounds like a good combo, if it fits.
      02-07-2012, 04:14 PM   #5
robertm
450
Drives: 2020 M2 Comp
How do you know they will rub? Have you tried specific tire in that specific size? Just wondering if that actual tire has been confirmed to rub. Thanks!
      02-07-2012, 08:49 PM   #6
bklounge
bklounge's Avatar
52
Drives: VO 1M
From the michelin website
Stock PS2's:
245/35/19 - diameter = 25.8"
265/35/19 - diameter = 26.3"
PSS:
255/35/19 - diameter = 26.0"
265/30/19 - diameter = 25.3"
295/30/19 - diameter = 26.0"
265/30r19 F and 295/30r19 R shouldn't rub the top of the fender liner due to the smaller diameter than stock, but they are beeefy and better suited for a 9.5"/10.5" rim combo.
      02-08-2012, 12:16 AM   #7
///M1
///M1's Avatar
273
Drives: Many
I should clarify, I was referring to a 265/35/19 PS2 tire, that does rub. I have not tried with the same size for a PSS, but as you can see the diameters as given by TR are the same, so there is nothing to indicate moving from a PS2 to a PSS in that size (265/35/19 up front) will cure the rubbing. And it is not a matter of a fender roll (those are done courtesy of the factory, contrary to the 135i), it rubs top of the fender inner liner. So if a PS2 rubs, I think it is a safe bet the PSS will rub, as if anything, it is a lot more square tire than the PS2 (the edges don't seem to curve as much as on the PS2s, but rather more of a square setup like the Bridgestone RE-11s)
      02-08-2012, 05:10 PM   #8
robertm
450
I am definitly going wider on the next set of tires. First and most of second gear is kind of a joke right now. Here's what I found on Tirerack. All prices are before shipping.
Here's the 3 or 4 best options as I see them:
265/30ZR19 XL Michelin Pilot Super Sport
295/30ZR19 XL Michelin Pilot Super Sport
$1568
265/30ZR19 XL Continental ExtremeContact DW
285/35ZR19 Continental ExtremeContact DW
$1064
265/30ZR19 XL Hankook Ventus V12 evo K110
295/30ZR19 XL Hankook Ventus V12 evo K110
$1044
285/30ZR19 XL Hankook Ventus V12 evo K110
$1012
The Michelins PSS seem to be the uncontested best of the best. At 50% more cost than the other options though it may not be worth the money to some. Between the other two it seems the Contis are a bit better. But with the Hankooks you can get to the 295 width in the rear.
I have a few months to go before I need new shoes. I'm hoping some other folks try a few of these out in the mean time!
      02-08-2012, 08:33 PM   #9
///M1
///M1's Avatar
273
Drives: Many
Robert, here are some statistics perhaps to help you in your decision when it comes time for it (at least from a dimension standpoint):
Stock fitment front: 245/35/19
Sidewall: 3.4
Radius: 12.9
Diameter: 25.8
Circumference: 80.9
Revs/Miles: 783
Going to 265/30/19
Sidewall: 3.1
Radius: 12.6
Diameter: 25.3
Circumference: 79.4
Revs/Miles: 798
Speedometer reading with non-stock tire is 1.9% too fast (when traveling and your speedo is reading 60mph, you are actually going 58.9mph)
Going to 255/35/19
Sidewall: 3.5
Radius: 13
Diameter: 26
Circumference: 81.8
Revs/Miles: 775
Speedometer reading with non-stock tire is 1.1% too slow (when traveling and your speedo is reading 60mph, you are actually going 60.6mph)
Stock fitment rear: 265/35/19
Sidewall: 3.7
Radius: 13.2
Diameter: 26.3
Circumference: 82.6
Revs/Miles: 767
Going to 295/30/19
Sidewall: 3.5
Radius: 13.0
Diameter: 26.0
Circumference: 81.6
Revs/Miles: 777
Speedometer reading with non-stock tire is 1.3% too fast (when traveling and your speedo is reading 60mph, you are actually going 59.2mph)
Going to 285/30/19
Sidewall: 3.4
Radius: 12.9
Diameter: 25.7
Circumference: 80.8
Revs/Miles: 784
Speedometer reading with non-stock tire is 2.2% too fast (when traveling and your speedo is reading 60mph, you are actually going 58.7mph)
      02-08-2012, 08:55 PM   #10
bklounge
bklounge's Avatar
52
Drives: VO 1M
$1568
$1064
$1044
$1012
You can get the extremecontact DW in 285/30/19, but tirerack recently dropped that size from their site last week. It's still available on other sites though.
      02-08-2012, 08:56 PM   #11
M1one1M
Australia
12
Drives: nothing
Why wouldn't you guys just go one size bigger all around with the PSS's
F: 245/35/19
R: 265/35/19
To:
F: 255/35/19
R: 275/35/19
This way you are keeping the same ratio between front and rear as stock but still getting more rubber down.
      02-08-2012, 09:12 PM   #12
bklounge
bklounge's Avatar
52
Drives: VO 1M
F: 245/35/19
R: 265/35/19
To:
F: 255/35/19
R: 275/35/19
Due to mad amounts of rubbbing as someone already pointed out. (in the front especially)
      02-08-2012, 10:12 PM   #13
M1one1M
Australia
12
Drives: nothing
I can't recall reading anywhere above that a 255 had a "mad amount of rubbing"
      02-08-2012, 10:37 PM   #14
dd7511
Indonesia
Drives: BMW 1M VO
I am running 255/35 & 275/35 on my stockers. Michelin PSS
M3 GTS same wheel size is running 255/35 & 285/30 on Pirelli Corsa
      02-08-2012, 10:39 PM   #15
///M1
///M1's Avatar
273
Drives: Many
The PSSs are fairly new and Michelin is continuing to make more sizes available. I am hoping 285/30 is one of them!
      02-08-2012, 11:55 PM   #16
HP Autosport
Supreme Allied Commander
3816
Drives: F80 M3
255/35R19 PSS will rub(we have mounted this upgrade on a customer's 1M, 255/35R19 front and 275/35R19 rear PSS) on the exhaust vents of the oil and water cooler first at and near full steering lock before it will rub on the top of the fender liner(this can only happen if you lower your car too much, at stock or 1" lowering there is not enough compression travel for this to happen).
      02-12-2012, 01:49 PM   #17
Todd
27
Drives: 2020 M2
Does the pictured car have any spacers on the wheels?
      02-12-2012, 03:56 PM   #18
HP Autosport
3816
Drives: F80 M3
No, just the upgraded tires and wheel studs and nuts.
TC Kline Racing Double Adjust coilover system is next.
      02-12-2012, 06:41 PM   #19
M1one1M
Australia
12
Drives: nothing
Exactly!
      02-12-2012, 06:44 PM   #20
M1one1M
Australia
12
Drives: nothing
Is the black car lowered at all?
      02-13-2012, 01:41 AM   #21
HP Autosport
3816
Drives: F80 M3
No, not at all. That is why the TC Kline Koni based double adjust coilovers is going on next.
      02-13-2012, 05:23 PM   #22
M1one1M
Australia
12
Drives: nothing
So you're saying that 255/35/19 will rub in the front on stock suspension?
1addicts
