Transmission issue?!?
02-01-2012, 08:21 AM | #1 |
104
Rep 596
About a year ago, brought in my E90 to the dealer regarding a transmission leak. They ended up replacing the Mechatronic sleeve. Now, the vehicle has left a small residue on the same area as last time, and I'm also noticing the vehicle shifting a bit weird. From a cold start, as you coast from first -> second (6AT), the engine idle revs up another 200-400rpms between shifting. It goes bout 200rpms when shifting from second to third gear. Any thoughts?
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
02-01-2012, 08:57 AM | #2 | |
103
Rep 2,783
02-02-2012, 02:03 AM | #3 |
1622
Rep 3,402
Not so sure it is a level issue. There are a lot of possibilities but all will involve the dealer figuring out what is wrong. Small residue and no fluid on the floor makes it fairly unlikely it is a fluid issue and if it was from the last transmission service I think it would have been an issue long ago. There is a series of solenoids that actually initiate the shifting so it could be one of them. Best of luck
