Does a deployed airbag cause any damage?
01-30-2012, 08:49 PM | #1 |
12
Rep 105
So i found this perfect coupe 335i.. Except its been in an accident that caused its airbag to deploy and had to be towed.. The steering wheel was also replaced probably because of the drivers head hitting it.. : . Anyways my question is does the steering wheel being replaced and the airbags being deployed cause any actual damage if they fixed the car? Would i be able to know if the car had been hit pretty bad now or not? Would i be able to get the price down to 25k? Here is the car...
http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=314595081&dealer_id=64590281&c ar_year=2008&systime=&doors=&model=335I&search_lan g=en&start_year=2008&body_style=COUPE&keywordsfyc= &keywordsrep=&highlightFirstMakeModel=&search_type =both&distance=75&min_price=1&rdm=1327977642455&dr ive=&marketZipError=false&advanced=y&fuel=&keyword s_display=&sownerid=51167445&lastBeginningStartYea r=1981&end_year=2013&showZipError=n&make2=&certifi ed=&engine=&dma=MIAMI-FT_LAUDERDALE_FL&page_location=findacar%3A%3Aispse archform&body_code=2&isFlashPlugin=false&transmiss ion=&default_sort=&max_mileage=45000&color=&addres s=33060&sort_type=priceDESC&max_price=26888&make=B MW&seller_type=b&num_records=25&cardist=34&standar d=false |
01-30-2012, 08:52 PM | #2 |
183
Rep 2,063
Drives: 2007 335i Coupe
Garage List 1991 BMW E30 325i s ... [8.50]
1995 BMW 318Ti [0.00] 2007 BMW 335i Coupe [10.00] 1962 VW KarmanGhia [10.00] 2007 BMW Mini Cooper [9.00] |
If airbag deployed meaning structural damage... so don't not even for 25K .... NOOOO!
01-30-2012, 09:04 PM | #3 | |
12
Rep 105
01-30-2012, 11:34 PM | #4 |
183
Rep 2,063
If it did not hit any structure the airbag wont deploy... and they want 25K... I say 15K that's all you should offer them... walk away there is alot other out there... If you can sense that there is something not right... then it means that it is not right...
01-31-2012, 12:14 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
Airbag deployment is based on detected rate of deceleration.
01-31-2012, 04:31 AM | #7 | |
103
Rep 2,783
01-31-2012, 08:15 AM | #8 | ||
12
Rep 105
01-31-2012, 08:22 AM | #10 | |
NHTSA Nazi
28
Rep 1,983
First gen airbag cars had hardwired sensors behind the bumpers - whack it hard enough and it'll go off, but all that is changed now. |
01-31-2012, 08:23 AM | #11 |
183
Rep 2,063
$25K????!!!! No way I don't care what they say or the others might think.... Walk away my friend... find a CPO... this is a NO-BRAINER
01-31-2012, 08:36 AM | #12 |
52
Rep 1,746
01-31-2012, 09:38 AM | #13 |
atlien
15
Rep 371
Drives: '11 e90 335i
I would never buy a car if I knew the airbag had been deployed. there are so many cars out there, go find one that hasn't been wrecked! You think you're getting a good deal but any money you save up front on the purchase price you will end up shelling out in the end because there will be a lot of stuff that wasn't fixed properly and you'll have no idea until things start failing, breaking, and falling off
2011 e90 335i: AW/Oyster | M Sport | BMW Performance (Power Kit v1, Exhaust, Suspension, rear and side aero kit, 19" 313s)
01-31-2012, 09:56 AM | #14 |
25
Rep 691
I don't know about the OP, but knowing my car was in a serious accident (in this case, air bag deployed) will definitely bug the holy shi# out of me, there are going to be tought on the back of my mind, what happened and what didn't get fixed or didn't get fixed right, and whats going to break soon .... to many concerns, thats going to drive me nuts
01-31-2012, 10:04 AM | #15 |
183
Rep 2,063
"Would i be able to know if the car had been hit pretty bad now or not? Would i be able to get the price down to 25k? Here is the car..."
Hey guys i read what OP posted again... they are even asking for more than 25K???!!!! what the?!! |
01-31-2012, 10:16 AM | #16 | |
Rep 344
Drives: 09 E93 CR.
first off it does not mean that there is structural or frame damage just because the airbag deployed. it could of been a simple fender bender causing the airbag to deploy. Especially on these vehicles since there are two airbag crash sensors right behind the front fender by the headlights. as for wanting 26k for it, its not that bad but i would say offer them 23-24k since it did have a deployed airbag. and even after the airbag has been deployed and then replaced this does not cause a weakened safety system in the vehicle. everything will still work as it should. I'm not trying to sell you or the vehicle but I am in the business and I'm just giving my point of view from a professional in the business. ***also if you really wanted to purhase a vehicle alot of dealers would let you take it to a repair facility or dealer to have it inspected before you buy it. I do that if my customers want. But it's at your(the customers) expense. |
01-31-2012, 10:21 AM | #17 |
18
Rep 632
I wonder if you taped a football to the steering wheel would it come off with enough force to jack you up if the airbag deployed?
01-31-2012, 10:38 AM | #18 |
atlien
15
Rep 371
only one way to find out
01-31-2012, 11:08 AM | #19 | |
183
Rep 2,063
01-31-2012, 11:56 AM | #21 | |
Rep 344
Drives: 09 E93 CR.
I'm just stating the facts man. LIKE I TOLD HIM AND I'LL TELL YOU TOO: I AIN'T TRYING TO SELL THE CAR NOR AM I TRYING TO SELL HIM. people tend to become arrogant douche-bags when they hear an airbag or two was previously deployed and think that major damage was done and the car isn't safe anymore. I just stated that the vehicle DID NOT have to be hit hard to sustain frame or structural damage for the airbag to deploy. I just offered an opinion on what i think he should have paid IF he wanted the vehicle. and the vehicle was for sale on autotrader.com listed by a DEALER(NOT BMW DEALERSHIP). ALSO I stated that and I quote myself: "***also if you really wanted to purhase a vehicle alot of dealers would let you take it to a repair facility or dealer to have it inspected before you buy it. I do that if my customers want. But it's at your(the customers) expense."......In the quote there I never said anything pertaining to this specific vehicle he wanted to buy. I stated that ALOT OF DEALERS(wheter private or not) WOULD LET YOU take the vehicle for a PRE-SALE INSPECTION. The choice of where is upto you hence I said REPAIR FACILITY OR DEALER(meaning BMW dealership) and its at the customers(in this case if he wanted to get it done to know info on the car, HIM)....So don't try to bash me man. |
01-31-2012, 12:01 PM | #22 |
224
Rep 699
Airbag doesn't always mean structural it can just mean that there was a pretty big change in velocity in a short span of time.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
