FS: NHT loudspeakers, Pioneer Elite Receiver, Voledyne Subwoofer
05-29-2007, 02:07 AM | #1 |
www.signettour.com
15
Rep 297
Hi guys I am selling my home theater system. All system works prefect and in mint condition. If you buy it all togther, the price will be $550.00 1. NHT supertwo loudspeakers in mint condition $250.00 / pr System Type: 3-way, vented Drivers: 6.5" long-throw subwoofer, 6.5" midwoofer, 1" fluid cooled soft dome tweeter (video shielded drivers) Response: 35Hz-25KHz +/-3dB Sensitivity: 87dB @ 2.83V/M Impedance: 8 ohms nom.,(3.8 min.) Suggested Amp. Power: 25w/ch - 175w/ch Dimensions: 39"H x 7.25"W x 10"D Weight: 39 lbs. each Finish: High-gloss black laminate 2. Pioneer Elite VSX-33TX THX Select Surround Receiver $150.00 Power Stereo: 100 Watts per Channel (20 - 20 kHz, @ 6 ohm, 0.09% THD) Surround: 80Watts x 5 (20 Hz to 20k Hz, .09% THD) Direct Energy MOSFET Amplifier Design Direct Construction Design Extruded Aluminum Heat Sinks with Direct Current Bus Bar Isolated Chamber Construction Digital Decoding and Processing THX-Select Certified Dolby Digital 5.1 Decoding DTS 5.1 Decoding 24-bit Digital Signal Processing (DSP) 24-bit Analog to Digital (A/D) Converters 96k/24-bit Digital to Analog (D/A) Converters - 6 Channels 6 Acoustic Environment DSP's Hall 1 Hall 2 Jazz Dance Theater 1 Theater 2 5 Channel Stereo Advanced Theater Modes Drama Musical Action 5-D Theater Midnight Mode Multi-Channel Tone Controls Multi-Channel Digital NR Connectivity DVD-A Ready 5.1 Channel Input Pre-Amp Output (ALL) 4 Digital Inputs (3 Optical/1Coaxial)/1 Digital Out (Optical) Inputs - 4 Audio/5 Audio/Video CD AUX CDR/TAPE TUNER DVD/LD TV/SAT VCR/DVR VCR 2 Front Outputs - 2 Audio/2 Audio/Video/1 Video CDR/TAPE Audio Output Tape 2 Ouptut VCR/DVR Audio/Video Output VCR 2 Output Monitor Video Output S-Video (4 Inputs/2 Outputs) DVD/LD Input TV/SAT Input VCR/DVR Input Video (Front Panel) Input VCR/DVR Output Monitor Output Front A/V Input w/S-Video In Independent A/B Speaker Switching Banana Speaker Terminals (ALL) 3. Velodyne 10" Subwoofer (VRP-1000) in new condition $150.00 Built-in powered amplifier: Bring your favorite movies to life with rich, powerful bass provided by the 115-watt RMS amplifier. 35Hz-140Hz frequency response: Get the full impact of your favorite movies with a 35Hz bass response, which lets you feel the action as well as hear it. Line-level inputs: Connect the subwoofer directly to the subwoofer output on your receiver with an RCA patch cable using this type of input. Speaker-level inputs: Connect the subwoofer to the speaker wire inputs on your receiver with speaker wire using this type of input.
///M
05-29-2007, 12:36 PM | #4 |
www.signettour.com
15
Rep 297
i brought the speakers and receiver since 2004. the subwoofer is 3 month old. all in good working condition. the reason i am selling it is i am moving back to taiwan.
///M
05-31-2007, 12:17 PM | #6 |
292
Rep 2,414
Drives: E92 335i
:BUMP:
