Strange scraping, grinding noise from rear
01-22-2012, 04:29 PM | #1 |
34
Rep 356
My car is a 2006 BMW 323i. It has approx 70k miles on it. It started making a scraping noise, not too loud, from the rear, that sounds like a worn through brake pad rubbing on a caliper. The only thing that stumps me is that it only makes the noise when in gear. Which rules out the brakes. I changed the rear diff oil today and it made no difference. As soon as I touch the clutch the noise goes away. What gives? Any ideas or suggestions? Could this be a worn center diff bearing?
Btw, it is not a wheel bearing, sound does not change when going left or right. I also noticed a little bit of a clunk / click noisewhen transferring from decel to accel and back. Tranny shifts smooth as a baby's bum as well I have a lot of exp working on cars, Audi in specific, just not BMW |
01-22-2012, 04:53 PM | #2 |
82
Rep 2,446
Last week I was quoted 3200$ by the dealer to change the whole differential. 60000 miles. lol. I didn't ask about anything. In a test drive for a suspension issue, chief mechanic just heard an high pitch mechanical noise.
03-24-2012, 10:00 PM | #4 |
Rep 1
I think I have the same issue on my 2011 335i Coupe with just 6K miles. The noise is relatively faint -- you can hear it best in 4th or 5th gear at 1000 rpm or a little above (i.e., with not too much road noise), and it usually becomes quite faint when the car is warm. It does disappear when I step on the clutch.
Had my car in for service last week, and had played a recording to the service guy. Got the car back after waiting a few hours, with the noise reappearing after the car had cooled down for a few hours. :( May give the service another try... |
03-24-2012, 11:02 PM | #6 |
60
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
Are you sure it's not the wheel bearing? I had loud scraping noises and they ended up changing the wheel bearing/wheel hub under warranty.
10-03-2014, 06:31 AM | #7 | |
Rep 2
Did you find out what was causing the noise? I have the exact same noise on my 2006 E90 323i. I am really looking for a solution to this. The car has got 130000km but it's been well looked after. It also makes the noise only in gear and moving. I can only hear it when the radio is off and the windows are up. It is the same noise you have described. I just hope it's not diff or gearbox. I would find it hard to believe that the diff or gearbox is already failing, I had an e46 before and no issues like this. |
10-03-2014, 07:44 AM | #8 |
44
Rep 604
Drives: 2009 328i xDrive
Did you recently take off your rear wheels? Maybe they are not flush when you put them back on. Happened to me
10-03-2014, 11:04 AM | #9 |
299
Rep 2,015
Is your ebrake working properly.
How many clicks to lock rear wheels? The only other option, take it to a shop that can run your car while on a hoist. DN |
