01-07-2012, 12:16 PM | #1 |
Supreme Allied Commander
3842
Rep 54,352
Drives: F80 M3
>> HP Autosport<< BMW 1M Ferodo DS2500 Brake Pads Member Pricing
Available now BMW 1M and M3 applications!
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat. When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, HPA would recommend the Ferodo DS3000 or DS1.11. Front pads: $221.00 Rear pads: $213.00 Oder here: https://hpautosport.com/product/ferodo-1m-brake-pads/ Best brake pad backing plate great money can buy: https://www.amazon.com/gp/product/B0...9bf8ea5d022ad2 Last edited by HP Autosport; 07-08-2023 at 08:40 PM.. |
01-09-2012, 08:07 PM | #2 |
18
Rep 140
Hi,
Do you offer a brake pad that doesnt squeal? Quietness is primary for me, performance secondary. 2011 BMW 135i coupe. Thanks.
2017 BMW 440i Blk/Blk-Blu Stitch | Auto | M-Sport | Nav
01-10-2012, 03:55 PM | #3 |
3842
Rep 54,352
Drives: F80 M3
02-11-2012, 09:44 AM | #4 |
18
Rep 140
Hi there,
One member suggested I take off pad sensor and ziptie it somewhere which would eliminate my brake squeaky noise problem. What do you think of this solution?
02-11-2012, 11:42 AM | #5 |
3842
Rep 54,352
Drives: F80 M3
Pad wear sensor has nothing to do with it, unless your pads are so worn and your sensor is riding on your rotor. If that were the case, shouldn't you be replacing your pads, instead of just relocating the sensor?
02-11-2012, 05:12 PM | #6 |
18
Rep 140
Correct, but I was told I have 9mm left.
03-07-2012, 02:42 PM | #7 |
Rep 66
Is there a discount for 135i brake pads maybe? Currently looking for a good set of street/track pads and from what I've read so far ds2500 Ferodo are the ones to get....
03-07-2012, 03:16 PM | #8 |
3842
Rep 54,352
Drives: F80 M3
03-19-2012, 04:28 AM | #9 |
M-addict
Rep 62
Drives: M3 e92 Laguna seca, M5 f90 Com
Garage List 2021 BMW M4 GT4 202 ... [0.00]
2019 BMW M5 F90 Comp [0.00] 2010 BMW M3 e91 [0.00] 2013 BMW M3 e92 [0.00] |
So are they compatable with pad sensors? If yes, do I have to buy new ones each time I replace the pads?
Thank you!
In wroom I trust.
BMW M3 e92 Laguna Seca Blue '13 BMW M3 e91 Tourmaline Violet '10 BMW M5 F90 Comp Peridot Green '19 BMW 1M Valencia Orange '11 (sold) |
03-30-2012, 04:23 PM | #10 |
3842
Rep 54,352
Drives: F80 M3
Yes, they are compatible.
If the brake pad wear sensor light comes on, then new sensors are needed. Otherwise, you'll need to inspect them and make the call yourself. They do sometimes break when removed them from the old pads. |
04-11-2012, 12:36 PM | #11 |
3842
Rep 54,352
Drives: F80 M3
Ferodo DS2500
1M Street/HPDE/Track Day pads in stock!
Don't ruin your street pads any longer! FREE Stoptech STR600 brake fluid with any brake pad purchase! |
06-04-2012, 10:45 PM | #12 |
247
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
When will they be in stock for 135?
///1M #643 of #740
06-05-2012, 11:37 AM | #13 |
3842
Rep 54,352
Drives: F80 M3
06-05-2012, 03:48 PM | #14 |
18
Rep 140
HP Autowerks,
What is your current recommendation (brake pads) for a 2011 BMW 135i coupe? I am not interested in tracking, just something inexpensive to replace my squeaky brakes.
06-14-2012, 11:53 PM | #15 |
3842
Rep 54,352
Drives: F80 M3
09-24-2012, 11:47 PM | #16 |
137
Rep 718
Drives: N/A
HPA,
I installed the pads last week which I bought from you guys. But my installer told me the back sensor cant put them back on the pad, any idea or suggestion?
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
09-25-2012, 01:11 PM | #17 | |
3842
Rep 54,352
Drives: F80 M3
I will make sure Ferodo is aware of this issue. Last edited by HP Autosport; 09-25-2012 at 01:50 PM.. |
01-25-2016, 12:47 AM | #21 |
3842
Rep 54,352
Drives: F80 M3
The price actually went up again.
Price listed in the original post is the member pricing. |
