TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > For Help with NCSExpert Errors
      12-02-2011, 12:22 PM   #1
Elliott@DetailAddict
302
Drives: E90
Exclamation For Help with NCSExpert Errors
Please do NOT just post the error dialogue that pops up at the time of the error.
For example, posting JUST this WILL NOT HELP:
Click OK on that error, and the go to VIEW and the ERROR LOG:
Post what is in there for answers.
As you can see from my example, the error log shows me that when editing my WL_NSW line in the NFRM, I entered in an incompatible value.
Cheers
      01-12-2012, 03:10 PM   #2
KevinJ
18
Drives: 2k11 335is
Haven't seen a fix for this:
When attempting coding CIC. The VO writes were successful however:
ERROR! Modul: CDHINT.CPP, Proc: CDHIntSetScriptFile, LineNr: 02, ErrorNr: 1060
COAPI-1060: error in coding discription file
A_CIC
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 02, ErrorNr: 1000
A_CIC
>> ERROR! Modul: COAPI.CPP, Proc: coapiReadCodierIndexFromSg, LineNr: 05, ErrorNr: 1000
CODIERINDEX_LESEN: A_CIC
A_CIC
A_CIC
A_CIC
A_CIC
A_CIC
A_CIC
Thanks!
Just noticed a cabi.err file which has this in it:
C:\NCSEXPER\sgdat\a_cic.ipo(1) : error I300: Error opening object file
I do not find a_cic.ipo in that location. If I go to the V42 daten source sgdata directory, I do see a_cic.ipo. However running the daten batch file does not add this file. Don't want to just assume I should take everything from sgdata and dump it into the NCSEXPERT sgdata directory but that seems like the likely solution I think.
      01-12-2012, 03:44 PM   #3
KevinJ
18
Drives: 2k11 335is
Arrgghhh, I think I know what I did. I had earlier issues a month or so re-installed. So today I was just updating the daten files by running the script but didn't bring my ecu and config files update V42 with the daten update.
      01-17-2012, 10:53 PM   #4
Ninjasane
Drives: Pre-LCI E90 335i Jet Black
running win7 ulti with winxpmode attached usb and when i click on airbag i get a identification error(sys-0012 error). it exits the screen which makes it impossible for me to even show you an error log. some research suggested I check C:\Ediabas\Ecu to make sure i have MRS5.prg which was there. anyone know what i need to do to make the airbag test work?
      01-18-2012, 12:06 PM   #5
302
Drives: E90
That error screen doesnt apply to INPA. Most don't get the airbag test to work but code no problem. Skip and move on to NCS.
      01-31-2012, 01:28 PM   #6
Len_Beach
188
Drives: 435d
I'm trying to read the DWAI module but keep getting this error:
Error in cabd. Look at cabi.err and error log
Coapi 2000: ediabas or sgb error
Sys-0004; illegal format of ecu object file
ERROR! Modul: LFCDHDIA.CPP (A_E65C.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
COAPI-2000: EDIABAS or SGBD error
SYS-0004: ILLEGAL FORMAT OF ECU OBJECT FILE
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000
CODIERINDEX_LESEN
>> ERROR! Modul: COAPI.CPP, Proc: coapiReadCodierIndexFromSg, LineNr: 05, ErrorNr: 2000
CODIERINDEX_LESEN: A_E65C
CODIERDATEN_LESEN
I'm running Ediabas 7.2 and V43 Datens (I think!).
Any thoughts?
Thanks
      01-31-2012, 01:59 PM   #7
302
Drives: E90
Sounds like a bad file (A_E65C).
Try to update with v45.
The DWAI is connected and installed properly?
      01-31-2012, 02:08 PM   #8
Len_Beach
188
Drives: 435d
Thanks Grant.
I'll have a look for V45 and try the update.
Good question On being installed correctly. The clown nose under the mirror flashes and I have an alarm according to my VIN but I've not seen it in action.
Any idea how I'd test it?
Thanks again.
      01-31-2012, 03:17 PM   #9
302
Drives: E90
Well if it is showing up in the module list it should be ok. Is the siren installed correctly in the wheel well also?
      01-31-2012, 03:21 PM   #10
Len_Beach
188
Drives: 435d
I've not checked the siren but am going to do some investigation at the weekend.
I've just been reading up on testing using the panic mode, check the plunger under the bonnet etc. I'll see what that yields.
Many thanks for your input Grant.
      01-31-2012, 04:46 PM   #11
302
Drives: E90
Well unless it's been coded those tests won't apply to you. They may or may not function after just installing the system. Glad to help
      02-01-2012, 02:16 PM   #12
Len_Beach
188
Drives: 435d
Done some more digging tonight.
It would appear that I have an alarm plunger under the bonnet by the bulkhead on the right.
I coded Panikalarm and Alarm Beep in CAPPL and neither options work.
The other coding I did in the CAS, KOMBI and CAPPL all worked just not the alarm related.
Would this suggest an issue with the DWAI module?
      02-01-2012, 04:00 PM   #13
302
Drives: E90
Are you coding the kombi, and nfrm with the vo properly first? Then code the kombi cas nfrm dwai and dwas in expert mode?
      02-01-2012, 04:30 PM   #14
Len_Beach
188
Drives: 435d
Hi Grant.
I'm just trying to code a few features such as alarm beep etc, not retrofit the alarm. Would this require VO amendments?
The car is a 2007 M3 which was bone stock as far as I was aware when I bought it last June.
I used BMvininfo to check the options and it lists option 302 Alarm and option 8S2 Coding of alarm signal.
I'm going to check for the siren at the weekend but am beginning to wonder if there is a hardware issue.
      02-01-2012, 05:01 PM   #15
302
Drives: E90
Sounds like a bigger issue if the alarm was there from factory yet the panic isn't working etc.
And no, you would not need to edit the VO to change single values like that.
      02-02-2012, 04:52 AM   #16
Len_Beach
188
Drives: 435d
After a little more work, I reinstalled the V43 Datens as I've not found a working V45 yet and tried again.
I still can't read the DWAI but I now have the menu option for alarm beeb which works when activated.
The Panic Alarm doesn't work so I'm going to re-check my coding on that when I get home from work.
      02-02-2012, 10:35 AM   #17
302
Drives: E90
Definitely sounds like bad data. I can link you to a working v45. PM me.
      02-02-2012, 10:55 AM   #18
Len_Beach
188
Drives: 435d
Thanks Grant. PM sent
      03-07-2012, 04:04 AM   #19
M.Etreby
Egypt
36
Drives: 2011 Black Sapphire E90 330i
Originally Posted by Len_Beach View Post
Thanks Grant.
Thanks again.
Len, any luck with V45?
M.Etreby
F M double Grills, 19"313, Perf.Exhaust with dimisatips, RPI red scoops, K&N filter, LUX-H8 160, Aluminum strut bar, PBX, Perf. Suspension, F30 M-Perf. Brakes
      03-07-2012, 05:31 AM   #20
M.Etreby
Egypt
36
I got this error, any ideas?
M.Etreby
      03-07-2012, 12:34 PM   #21
302
Drives: E90
looks like you updated the files wrong and now can't access the NFRM which seems to be common on here.
Revert back to your old daten files and see if NFRM works again.
      03-07-2012, 06:21 PM   #22
M.Etreby
Egypt
36
will this get me to the old problem regaridng the RPM, fuel,etc....?
M.Etreby
