Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > spray paint...
      11-27-2011, 01:15 PM   #1
ForTheD
ForTheD's Avatar
19
Drives: 2007 e90 335i 6MT (ZSP)
2007 BMW 335i  [0.00]
spray paint...
Hey guys,
I keep spray paint on a shelf in my garage and it looks like I need to make sure an point it away from my car because it can spit when ever it wants...
I have since thrown that bastard can in the trash, and attempted to remove the paint with clay bar and rubbing compound. Those have only seemed to make the paint feel smoother...
Before I try any methods recommended by google, I thought I'd check with the pros who know what the e90 paint is like.
I think it has been on there for about 2 days and it can not be chipped off with my fingernail either.
Thanks for any help provided!
      11-27-2011, 01:41 PM   #2
like'n'i6
untuned
like'n'i6's Avatar
Drives: Montego Blue 328i
2000 grit wetsand but be very gentle. the less risky option would be using polishing compounds. regardless of which option, polishing and buffing would still be needed. i would only recommend wetsand as a last resort.
      11-27-2011, 03:04 PM   #3
PINeely
PINeely's Avatar
1086
Drives: 2013 535i, 2015 Tundra 1794
Hit that panel with compound and it should come off pretty quickly. Just polish and seal after and you will be good to go!
      11-27-2011, 04:21 PM   #4
chris328i
Drives: 328i
That sucks. Temperature change may have caused the can to spit? Prep Solve may remove it without hurting the OE paint?
      11-27-2011, 06:07 PM   #5
Envious Eric
37
Drives: nissan xterra, 335 soon
more aggressive claybar. Its relatively fresh, so it shouldnt be too hard yet. Then a machine compounding followed by a polish should restore the look and clarity of the paint. of course, seal the car afterward
      11-28-2011, 01:11 AM   #6
ForTheD
ForTheD's Avatar
19
Thanks for the help.
Yea it must have been the temp change, or I suppose it could have been one of my little ones playing around. I won’t know for sure since I did not see it, but I will for sure keep the cap on the cans and keep them away from the cars from now on.
I think I will stay away from the sandpaper for now. Although wet sand would get rid of the orange peel right.
Would this count as a more aggressive clay bar?
http://www.amazon.com/Meguiars-C-210.../dp/B0009IQYEO
I suppose if anything this will give me a reason to get polisher.
      11-28-2011, 08:58 AM   #7
328i
328i's Avatar
148
Drives: E46 ///M
I would first try a solvent such as Prep-sol, even before claying with an aggressive clay, wet sanding would be my last resort. Keep in mind that usually an aggressive clay can cause micromarring as well, so you will need to polish the area afterwards if you go that route.
      11-28-2011, 09:41 AM   #8
jmscard
jmscard's Avatar
Drives: 2006 E90 330i Dinan S1
Easy-Off oven cleaner one and done...
      11-28-2011, 11:30 AM   #9
lopealle
Resident Black Guy
lopealle's Avatar
Zimbabwe
251
Drives: Lion
2006 M5  [10.00]
This...
Dude where have you been hiding
      11-28-2011, 12:52 PM   #10
Envious Eric
37
yes that is a more aggressive claybar.
prep-sol might work, but if not, stick with claying...you shouldnt have to wetsand that out. I would be really surprised if you have to go that route
      11-28-2011, 12:55 PM   #11
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
I've used gasoline with really good results on my cousin's vandalized Infinity. The spray paint came right off. Then I washed the area really well, polished it, then waxed it. The clear coat didn't get damaged at all and 2 years later you can't even tell anything happened to her car.
I was kind of afraid of the products that I bought, they all seemed so strong even though they were made for it, so I figured I'd start with something that automakers know is going to spill on a car occasionally.
good luck!
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
      11-28-2011, 01:08 PM   #12
328i
328i's Avatar
148
Drives: E46 ///M
Originally Posted by lopealle View Post
This...
Just been busy and picked up an E46 to replace my car so I've just lurked here mostly. I see you got an E60, is that sepang bronze? Looks amazing!
      11-28-2011, 02:38 PM   #13
ForTheD
ForTheD's Avatar
19
The prep-sol worked! It took some elbow grease, but it is of now.
The gas theory seems to make sense too.
Now I just need to seal it.
      11-28-2011, 04:39 PM   #14
328i
328i's Avatar
148
Drives: E46 ///M
Glad to hear it!
      11-28-2011, 06:19 PM   #15
wrickem
Big Beaver Smile
wrickem's Avatar
2101
I'm glad it worked out for you!
