Square Set up
11-23-2011, 11:47 PM | #1 |
48
Rep 504
Square Set up
I have a 2006 BMW 325i on St V1 Coliovers.Need your opinions if it will look aggressive and would I need any fender roll required.Give me your opinions/
Front: 18x8.5 et 35 235/45/18 Rear:18x8.5 et 35 245/40/18 Thanks, E90 Freak Last edited by E90 Freak; 11-28-2011 at 08:48 PM.. |
11-29-2011, 11:09 AM | #4 |
31
Rep 595
Why only square on the rims, and not the tires? You can do square 255/35 on 18x8.5. That's what I'm running now.
11-29-2011, 11:52 AM | #5 |
18
Rep 345
With those tire sizes you are going to have a lot more sidewall than the stock setup. Normally to keep the overall rolling circumference as close to stock as possible, when you increase the tread width (i.e. 225mm to 235mm,) you either stay the same aspect (40, aka 40% of 225 etc) or go the next step lower to 35. You went up in width and then also increased the ratio to the next level. Your speedometer is going to be off by a noticeable amount and your car is also going to look like the tires are much too thick IMO. With the sizes you listed your rear tires will actually be around .6 inches shorter in diameter than the front tires.
11-29-2011, 03:13 PM | #6 |
BimmerPost Supporting Vendor
2045
Rep 25,989
Those tire sizes are all over the place, so I would not recommend that setup. For those wheel specs a 235/40/18 all around would be more suitable.
VMR|Wheels | 714.442.7916 |
11-29-2011, 06:14 PM | #7 |
48
Rep 504
11-29-2011, 06:15 PM | #8 |
48
Rep 504
11-29-2011, 06:35 PM | #10 |
2045
Rep 25,989
Correct. No fender work necessary with a 235/40/18 on an 18x8.5 ET35 all around.
11-29-2011, 07:47 PM | #11 |
48
Rep 504
11-29-2011, 07:55 PM | #12 |
2045
Rep 25,989
You're welcome!
What tire brand/model were you planning on going with?
11-29-2011, 08:22 PM | #13 |
48
Rep 504
