Wheel guys chime in, want more aggressive fitment!
11-03-2011, 10:31 AM | #1 |
44
Rep 525
I've had the V710s on my e90 LCI for a while now specs are:
Fronts: 19 x 8.5 et 35 Michelin Pilot Super Sport Tires 235/35/19 Rears: 19 x 9.5 et 33 Michelin Pilot Super Sport Tires 265/30/19 I have a slight roll in the rear and none in the front, but I want to know how big of spacers (if any) I can have with a good fender roll in the front and the rear. I'm dropped on KW V3s. Anyone have this set up? I know that these tires run wide and might not have too much room for spacers. Also if you guys know any good places to get my fenders rolled around Los Angeles it would be appreciated. Nathan
11-03-2011, 10:33 AM | #2 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
I could make some rec's but pics would really be helpful for sure.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
11-03-2011, 10:36 AM | #3 | |
44
Rep 525
I'll get out and get some iphone pictures later today
11-03-2011, 10:38 AM | #4 |
505
Rep 35,580
Drives: JB 33ZERO
I would venture to say (without seeing it) you can get away with a 5mm in front, and maybe a 10mm in rr with your roll and only being 265's, but with the lci E90 it will be cutting it close. The pre-lci E90 had a bit more room back there.
11-03-2011, 11:32 AM | #7 |
505
Rep 35,580
Drives: JB 33ZERO
Looks pretty close as is... maybe 5mm front and rear is my best guess.
11-03-2011, 11:35 AM | #8 |
44
Rep 525
Front has some space but the pictures don't do it the justice. Do you think if I raised the coils a little and got a good roll I could do 10 mm front and 5 mm rear?
11-03-2011, 02:39 PM | #9 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Those specs are pretty flush as is. Spacing them out may cause rubbing. The best way to figure out what sized spacer though is to measure.
VMR|Wheels | 714.442.7916 |
11-04-2011, 12:22 PM | #12 |
505
Rep 35,580
Drives: JB 33ZERO
pm sent op
11-04-2011, 12:36 PM | #13 |
44
Rep 525
What's your idea on what I can fit?? Love your fitment, where'd you roll your fenders in socal?
11-04-2011, 12:46 PM | #15 |
167
Rep 2,174
You can run 12mm spacers all around with rolled rear fenders easy. My cuurrent set up 18x8.5 et35 w/12mm spacers front and 18x9.5 et 22 rear on my E92.
11-04-2011, 12:58 PM | #16 |
143
Rep 2,284
My setup right now is:
19x8.5 et35 19x9.5 et40 I added spacers to give it flush look that everyone wanted, so I went with 10mm front and 15mm in the rear. New offsets are measured et25 all around and provided me a flush look. My recommendation is to add a 10mm all around and you should be safe with the fenders rolled in the rear. |
11-04-2011, 03:23 PM | #17 | |
44
Rep 525
About how much does LTBMW charge? Where are they in socal? I'm thinking of 5mm all around or 10 mm front and 5 mm rear, just hoping it'll fit
11-04-2011, 03:26 PM | #18 |
557
Rep 5,367
iirc 40 per corner, any spacer smaller than 8mm will have no visual impact (only clearance). Start with 10 all around and or even stack them to see how your feelings change.
You can follow my builds on IG: Tee212 |
11-04-2011, 06:51 PM | #19 |
26
Rep 1,183
these are insane the size 18x10 front and 18x12 rear ahahaha
11-04-2011, 07:59 PM | #22 |
26
Rep 1,183
