Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Guess I'll be needing new shoes in the spring.
      11-02-2011, 01:15 PM   #1
JaSSon
Down with the N54.
JaSSon's Avatar
16
Drives: I has a E92!
These are my rear tires. They're 265/30/19 Evo V12's. They have roughly 12k miles on them The car is riding on a KW V2 suspension, but the rear spring perches are almost all the way extended, so there is little drop. Why did they wear so fast? I've done exactly 0 burn outs. Is there a way to correct the camber angle?
      11-02-2011, 01:49 PM   #2
NiVeDh
NiVeDh's Avatar
422
Drives: '08 E90 335i, '99 E36 M3
Looks like camber wear. How much negative camber do you have?
      11-02-2011, 06:16 PM   #3
JaSSon
Down with the N54.
JaSSon's Avatar
16
I'm not sure. I bought the car with the KWs installed already. Is the rear camber adjustable on he E92s?
      11-02-2011, 07:01 PM   #4
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Definitely has camber wear on those, but the toe wear looks pretty straight. I would suggest flipping your tires every so often if you plan on buying those tires again. You'll get a lot more life out of them.
      11-03-2011, 05:48 AM   #5
JaSSon
Down with the N54.
JaSSon's Avatar
16
That's something I'll do next year for sure. Is the rear camber adjustable at all to reduce wear some?
      11-03-2011, 10:30 AM   #6
ModBargains.com
475
Drives: JB E92 335i
When an E9X is lowered beyond the limits of just lowering springs (coilovers), the rear wheels toe-in excessively. This excessive rear toe can cause increased tire wear. A common fix is to upgrade the toe arms with some adjustable toe arms. Adjustable rear toe arms will fix this problem and will not only save the life of your tires, but will also improve the overall handling characteristics of your car. You may want to check out the Rogue Engineering Adjustable rear toe arms to help solve your problem!
