Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Should i get spacers?
      10-25-2011, 02:42 PM   #1
nyjrkm06
nyjrkm06's Avatar
Greece
44
Drives: 2020 330i
im looking for a more aggressive look. Im currently running
- 18"x8.5" ET35mm Front 235/40/18
- 18"x9.5" ET33mm Rear 265/35/18 gunmetal VMR v710's. Should i get spaces? will there be any issues? is so from where should i buy and what exact sizes.thanks
      10-26-2011, 07:49 AM   #2
nyjrkm06
nyjrkm06's Avatar
Greece
44
Drives: 2020 330i
      10-26-2011, 08:16 AM   #3
pe90zzi
CuL SToRY BRaHH
pe90zzi's Avatar
63
Drives: a purple thing
that set up is a generic flush set up. in other words with spacers you might have some rubbing issues due to the meaty tire set up you have. Also if you plan on going lower youll probably have some rubbing. if you want the wheels to stick out a bit more youll have to roll your fenders to minimize your rubbing.
I own a car
      10-26-2011, 08:21 AM   #4
mike3000fl
No_Country
138
Drives: 06 330i
agree with the above. you are sitting nice now, if you add spacers and plan to lower, you will most likely rub.
would look nice dropped as is.
      10-26-2011, 08:31 AM   #5
nyjrkm06
nyjrkm06's Avatar
Greece
44
Drives: 2020 330i
yea, this is an old pic of when i first got my rims. I have since lowered the car on eibach pro kit springs.
      10-26-2011, 08:34 AM   #6
pe90zzi
CuL SToRY BRaHH
pe90zzi's Avatar
63
you mind posting a pic of how the car sits now? possibly showing how the wheels sit with the drop?
thanks
I own a car
      10-26-2011, 08:47 AM   #7
nyjrkm06
nyjrkm06's Avatar
Greece
44
Drives: 2020 330i
thanks
no problem
      10-26-2011, 09:30 AM   #8
pe90zzi
CuL SToRY BRaHH
pe90zzi's Avatar
63
yeah on your tire setup id say your as flush as your going to be without crazy rubbing, if you want to get into specific mm's as far as spacers id do something real small, as in 5mm. 10mm wouldnt be horrible but you would have some rubbing, if you really want to do spacers 5mm wouldnt hurt all that much but youd still have some rubbing. Honestly for the setup as a daily (and if you dont want any rubbing) keep it as is, or throw some 5mms on and roll your rears.
IMO
I own a car
      10-26-2011, 09:47 AM   #9
cssnms
cssnms's Avatar
208
Drives: 2011 BMW 335d
Whether you should get spacers is a personal preferance and depends on how agressive you want your fitment/stance and if necessary are prepared to roll fenders to get that agressive fitment.
That said, if you want a more flush look without being super agressive, based on everything that I've read you could get away with a more agressive offset up front. Although I have an e90 LCI I believe our front tracks are the same. I am running the same size tire up front on a 19" 8.5" wheel et 35 lowered on Eibach's. and I am going to add a 5mm spacer, because after I lowered my car my wheel appears considerably more tucked and after measuring I have the room. I don't think I can go more agressive than that without rubbing issue.
I am running a 9.5" et35 on a 265/30 tire in the back but the LCI has a wider track than the pre lci, I am pretty tight back there, but I might be able to get way with a 2mm spacer without needing to roll. That said, I am generally pretty pleased with the rear fitment it's just the overhang in the front that bothers me, which I am hoping to cure with a 5mm spacer.
Keep in mind you are running a smaller diameter wheel so I think you can be slightly more agressive than some of us guys running 19's.
      10-26-2011, 10:19 AM   #10
nyjrkm06
nyjrkm06's Avatar
Greece
44
Drives: 2020 330i
IMO
Yes maybe I'll try 5mm I want the car to look really aggressive
      10-26-2011, 10:20 AM   #11
nyjrkm06
nyjrkm06's Avatar
Greece
44
Drives: 2020 330i
Yea I feel like I have some room between tire and fender
      10-26-2011, 02:12 PM   #12
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
The car looks pretty good as is!
We designed that fitment so that it would work without any rubbing issues at stock height with about as wide of a tire as you could get on them. If you wanted to space the wheels out I can't guarantee rub free fitment with those tire sizes and no fender work.
As always though, the size of the spacer you should get is totally dependent on your needs and wants. The best way to see how large you may be able to use is to measure the gap.
