PICS - 19x9.5 Front on lowered E92
10-25-2011, 06:54 AM | #1 |
24
Rep 158
Wanted to share a couple pics of a 9.5 et33 front on a lowered E92, just for documentation. When I originally searched, I could only find stock suspension examples or E90s.
Setup: (No fender roll) VMR VB3 19x9.5 et33 Front - 235/35 Continental DW 19x10 et25 Rear - 265/30 Continental DW Thoughts: The front wheel, without tire, is about 1mm away from the V2 strut body. Seeing that was a little scary, but so far I don't rub at all even on full lock. Without a roll in the rear, I rub slightly on dips or with rear passengers. With a roll I think this goes away completely. Lastly, the grip is insane. With this setup there is little to no under/oversteer, and the car feels very neutral. Even with Cobb Stage 1 Agressive, my tires don't spin unless I want them to do so. Also, the ride quality with the DW is much better than the stock run flats, but with this wide of a front I do tramline quite a bit more. On to the pics (Will update the thread with more detailed pics later): |
10-27-2011, 12:59 PM | #2 |
358
Rep 3,447
Drives: 2018 X3 M40i
Hey, I posted in your pic thread about your front wheel fitment.
So it IS cutting it pretty close. Is there room to go lower since the wheel is 1mm away from the strut? I had this issue when I was running 9" +38 for my old wheels, but I currently switched up my wheels and am running 9" +26 and lowered more in the front. And a fender roll will definitely take away the slight rubbing issue you have in the rear. |
10-27-2011, 01:18 PM | #3 |
24
Rep 158
Yep, it is very tight to the strut, but I think I can still go down another inch or so in the front without having any real issues with the fenders. I'll probably try it this weekend.
With the 9" +26, do you have any rubbing issues? What about in full lock?
10-27-2011, 01:57 PM | #4 |
748
Rep 4,429
Clean as Hell!! Love the last two pics!
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
10-27-2011, 02:49 PM | #5 |
BimmerPost Supporting Vendor
2042
Rep 25,989
I love it! Very classy combo, and it's very surprising to know that those fit. 1mm of clearance to the strut is pretty close though. Overall that setup looks awesome though. You can't go wrong with VB3s!
VMR|Wheels | 714.442.7916 |
10-27-2011, 04:07 PM | #6 |
358
Rep 3,447
No issues at full lock, and no rubbing. My rears are 10" +20 with 265/30 and I was able to get those not to rub either!
10-27-2011, 08:52 PM | #7 |
15
Rep 181
i have 19x9.5 et 22 up fronts no rubbing
10-28-2011, 04:16 AM | #9 |
40
Rep 2,334
nice
11-02-2011, 04:44 PM | #14 |
24
Rep 158
11-15-2011, 08:53 PM | #16 |
Bimmer Turbo Land
39
Rep 398
Here is mine w/ I-Forge Triumph w/ Yoko AD08.....has little rubbing issue which require minor fender roll work on the rear!! But it is all because of the AD08 thicker tire wall as I used to have a set of Falken 275-30-19 on the rear w/ totally not rubbing at all!! Moreover, I changed the all suspension arms to M3 setting inclusive the rear chamber link which able to render more camber for the ride though!!
Front as 19"x8.5" w/ tires 235/35/19 Rear as 19"x10.5" w/ tires 265/30/19 [/IMG]
Lumma BDK, M3 CF Hood, I-Forged Triumph 19", AP-6pt-360FR, AP-4pt-345RR, M3 CF Lip, ACS CF RFS, CF Grill, JB3 3.0, Stett DV CHG Pipe + DCI + FMIC, NST Pulley, F+R Full M3 Susp Kits, M3 E92 Q-pipes Ex, UR Catless DP, Ohlins C/O, Eibach Sway, M3 Dash Cockpit, CF Wrap Interior, M3 CF Pedals, M5 Shft Knob, LED ATW, OSS Design BlackOut LED Angel Eyes!!!
