Help on wheels fitment FOR xi e90
10-20-2011, 10:41 PM | #1 |
Rep 78
Hello everyone, apologies if this question had been asked before. I have a 2008 pre-lci 335xi 4dr sedan (non sport, completely stock)
I am looking to buy a set of wheels from a fellow forum member and here are the specs: Front 19x8.5 ET43 Rear 19x9.5 ET 21.5 Is the offset too aggressive in the rear? what do i need to do to make them fit? i.e. Rolling the rear fenders? I am relatively new to the World of BMW and any advice would be really appreciated Thanks very much!!!! |
10-20-2011, 10:57 PM | #2 |
168
Rep 3,900
Too aggressive but will work because A. Your stock and B. Your an XI ( sits higher). If your dropped these will rub and way to aggressive without fender rolling. Im on 19x10.5 offset 20 and fenders rolled and slammed and i rub. BTW you can run that offset in the front but its going to stick in a lot. Run a 15mm spacer and youll be fine. 34-37mm offsets are stock i would stay in the range of 25-35mm range.
10-20-2011, 11:10 PM | #3 |
Rep 78
Thanks for your advice, I suppose that's what I should be looking for in terms of offset 25 - 35mm range.
My goal is to find a set that fits easy with no rubbing/fender rolling so I will have no worry when I drop on a KW V1 next spring. Thanks |
10-20-2011, 11:22 PM | #5 |
Rep 78
ya, that's what I am trying to avoid. I have gone through these -3 camber and fender rollings and flush look with my previous car (EVO X). Right now just wanna enjoy the refinement and comfortable ride of a bimmer.
So my goal is probably to find a set that looks nice and not having to do any additional work (adding spacers are fine). and put on a set of V1 and I am all set. But thanks very much for your advice again. At least now I know what wheel offset I am looking for and trying to avoid. Thanks |
10-21-2011, 09:13 AM | #7 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
Wrong answer!
I am running 9.5 wide in the rear with 265/30/19 on H&R Sports with rolled fenders and still rub when I hit a major dip in the road. If you dont roll, and you lower the car, you are going to rub... no doubt about it.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
10-21-2011, 11:08 AM | #8 | |
Pro Hater
49
Rep 1,717
I'm lowered on 11" et32 (7mm out more than 9.5" et20) and do not rub. |
10-21-2011, 02:47 PM | #9 |
Rep 78
Will I rub with 265 tires in the rear with stock suspension (non sport), no rolled fenders and no neg camber?
Would it help if I do 235 front 255 rear to avoid rubbing? Last edited by seasonal; 10-21-2011 at 03:26 PM.. |
10-22-2011, 11:11 AM | #10 |
General
1569
Rep 29,202
Point is, not everyone will adjust camber and run stretched tires to make it fit.
10-24-2011, 08:07 AM | #11 |
Pro Hater
49
Rep 1,717
10-24-2011, 08:27 AM | #12 |
Rep 78
Thanks for everyone's input!!! I think running 255 tires on 9.5 wheels are not too stretched? I even saw on the AC Schnitzer website that's the recommended tire sizing for E90.
Again, thanks guys for your input, I have made up my mind to get these wheels. Eventually if I drop my car, I will probably be doing coilovers with camber plate and run neg -2 camber and that should be fine. Cheers |
