Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Powerservice additive
      09-30-2011, 07:12 PM   #1
duramax
16
Drives: 2011 335D
I am use to putting this in my diesel engines to help lubricate, etc. Why does the 335d say no additives?
      09-30-2011, 08:22 PM   #2
TotalPower
32
Drives: 2011 335is Vert AW
since the 335D has a urea spray in the exhaust the fuel additive's cetane boosters (or whatever metalic content it has) render the spray ineffective and may damage any particulate traps
      09-30-2011, 08:43 PM   #3
cssnms
cssnms's Avatar
208
Drives: 2011 BMW 335d
BMW says no fuel additives because it's not a product that is made/sold by BMW. Every other car manufacturer gasoline or otherwise also state no additives, but I still use Techron in my Lexus. I also use Powerservice with Cetane boost in my 335d.
Diesel Kleen is safe for the DPF.
http://www.powerservice.com/faq/#1
      10-01-2011, 11:33 AM   #4
duramax
16
Drives: 2011 335D
Thanks, I will start using it in the D.
      10-10-2011, 09:21 PM   #5
Deezl
Deezl's Avatar
Drives: 2011 Alpine White 335d
Are there any bmw diesel certified mechanics on this forum that can explain to me why bmw says not to use additives, other than "just because bmw doesn't make a diesel additive"?
      03-03-2012, 07:22 AM   #6
Deezl
Deezl's Avatar
...sent from a guy who drives a Gasser...
      03-03-2012, 07:34 AM   #7
DnA Diesel
27
Drives: 09 335d Sport SGrey/Blk/Blk
The only need for additives I would see are primarily for lubricity, and secondarily for cetane boost. Lower lubricity will have a cumulative detrimental effect on the interior working parts of the fuel injection system, while lower cetane primarily results in reduced combustion efficiency and cleanliness.
The biggest problem with diesel fuel in North America is reduced lubricity compared to European and other regions' diesel products. American diesel is known to have the worst lubricity (by national specification) at 520µm wear scar rating. 'Wear scar' refers to the size of the pattern of wear between two metal parts in a standard test jig; a larger wear scar on the test metal is worse than a smaller wear pattern. American diesel fuel specification (ASTM D975) requires lubricity that results in a scar pattern on the test metal to be no larger than 520µm. Canadian specifications require a maximum of 460µm. Most European countries have wear scar ratings between 280-320µm.
When considering what kind of additive to use, Arlen Spicer's lubricity report published in 2007 is pretty much the "state of the union" regarding qualitative and quantitative assessment of diesel additives available to the North American market.
Diesel Fuel Lubricity Additives - Study Results
by The Diesel Place and A.D. Spicer (2007)
In the end, the best lubricity additive was in fact addition of 2% soy biodiesel, followed by OptiLube products, Stanadyne Lubricity formula, Power Service - Diesel Kleen with Cetane Boost, and then some products that actually made lubricity worse!
Since up to 5% bio is okay by BMW, the best lubricity "additive" would be the 2% bio option, but if I did use an additive, it would be something like OptiLube Summer Blend or Stanadyne Lubricity Formula (protection and economical).
My 2¢
Cheers
D.
2016 GLE 350d - White on Black
      03-03-2012, 08:05 AM   #8
cssnms
cssnms's Avatar
208
Holy thread from 2011!
      03-03-2012, 05:43 PM   #9
F32Fleet
F32Fleet's Avatar
3566
Drives: 2015 435i
PS supposedly uses PTFE as it lubricity enhancer (not trying to imply anything just making it known). If it contains any sulphur your exceeding the min 15ppm for your tank of fuel ( max 15ppm finished product)
Search this Thread:
Advanced Search
