Oiling Air Filters?
09-23-2011, 08:50 PM | #1 |
Rep 132
Oiling Air Filters?
Hi All,
I typically do all my service work on my E90. One of the purchases I have made is replace the stock Air Filter with the K&N. After washing the filter, The K&N Spray Oil container doesn't produce an even amount over the filter due to the way it comes out of the spray nozzle. It would be great if the oil would come out as a mist - but this just doesn't happen. How do you ensure you get an even coat of oil over the filter? Fritzables. |
09-23-2011, 09:27 PM | #2 |
103
Rep 2,783
Go back to paper filter, I heard the oil will gum up the mass flow sensor wire.
09-23-2011, 10:40 PM | #3 |
Rep 132
Thanks Chriztofor, So far this hasn't happened (touch wood). I was considering finding a fluid that evaporates that wouldn't destroy the integrity of the filter then put a oil mix within then just let it sit to dry.
09-23-2011, 11:09 PM | #4 | |
21
Rep 780
I am skeptical of using this filter as right behind it is the MAF, at least pick up some MAF cleaner and clean your MAF when recharging the filter and once again after the first 5k. Last edited by Glim; 09-23-2011 at 11:48 PM.. |
10-08-2011, 08:11 AM | #6 |
Rep 251
Drives: 2012 BMW xDrive35i
That's only if you over oil it. Follow the directions when oiling it. Let it sit for a while, and you can wipe it some with a paper towel to get any extra oil off of the filter. Thousands of people do it, and never have a problem. If you have oil dripping off of it when you put it in your car, then you will have a problem.
2012 BMW X5 xDrive35i E70 Sport Activity
(Wife's Daily Driver) 2000 BMW 328ci E46 - less than 90k miles (Gone) 2007 BMW 335i E90 |
10-08-2011, 12:09 PM | #7 | |
7.62 x E90
15
Rep 324
Drives: 2012 Golf-R
10-08-2011, 12:27 PM | #8 |
44
Rep 1,011
i believe you are only supposed to oil the high exposed ridges... meaning not oiling in between the crests. plus only oil one side of the filter... the inlet side.
driving is poetry in motion. |
07-29-2013, 03:47 PM | #9 |
971
Rep 3,863
Drives: 330i, 135i
I am about to oil mine but how often you need oil your K&N filter? I bought it new last September I think so it has been almost a year.
07-29-2013, 08:48 PM | #10 |
General
17338
Rep 18,751
07-30-2013, 05:01 AM | #11 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
The key is not to over-oil. The oil bottle has a graduated marking - don't use more than recommended.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-30-2013, 06:25 AM | #12 |
1254
Rep 4,088
07-30-2013, 11:16 AM | #13 |
971
Rep 3,863
Drives: 330i, 135i
07-31-2013, 05:08 AM | #14 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
I've had a K&N for over two years, no problems. The squeeze bottle of oil works pretty well. That said, I don't like the oiling process and will probably switch to a dry filter next rime around.
If you live in a humid climate (like Florida), getting the filter completely dry for oiling is down time, about a half day. |
07-31-2013, 06:17 AM | #15 | |
General
17338
Rep 18,751
07-31-2013, 11:35 AM | #16 | ||
Diamond Geezer
212
Rep 2,385
