Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Best winter tire size...
      09-01-2011, 12:57 PM   #1
wiseweasel
The wisest of weasels!
Drives: Fast!
Hey all, i'm trying to determine the best winter tire size to go on my factory 7JX16 et:34 Model 268 wheels. I will probably throw some spacers in order to flush the tires out a little.
So the OEM runflats were 205/55/r16 but I'd like to improve the handling performance by going a little wider. Since the tires won't handle as well on dry pavement as those stock RFT's do. I know that going wider will hurt deep snow traction, but I'm willing to take a little hit there for improved performance over a tall skinny tire. Tire Rack has listed a 225/50/r16 as an alternative. But the only winter performance tire there is the Dunlop SP winter Sport M3. (not that it's a bad tire, i just was hoping for some options).
Can I go wider than 225 on these wheels? Any thoughts?
BTW, I did some searching and I didn't see much for the 16" wheels and winter options. Also, I am running 18" summer staggered for the warmer months!
      09-01-2011, 02:38 PM   #2
BMWsky
24
Drives: 335i
Wider tires only help in dry conditions, more narrow tires help in wet conditions as well as snow. (It doesn't have to be deep snow, either.)
With that being said, I run a square set of 17's for my winter setup. I think they're either 225 or 205, I can't remember. I'm using the Dunlop Winter Sports and am happy with them. Oh, and my car is RWD.
      09-01-2011, 04:13 PM   #3
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
For 16" winter setups, stick with the more narrow 205/55R16.
Winter
http://www.tirerack.com/a.jsp?a=AH8&...nter/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      09-06-2011, 09:47 AM   #4
wiseweasel
Drives: Fast!
Thanks Gary, my concern is that in Michigan, winter can often be 6 or more months! So I don't want to kill my handling. Are you recommending the 205's mostly due to tire options? I noticed many more tires available in that size on TireRack.com
Thanks!
      09-07-2011, 10:48 AM   #5
wiseweasel
Drives: Fast!
Okay, so lets say I stick with the stock size 205/55/16... how wide can I push with spacers? I have never run spacers before and I am a little concerned with durability, and overall effect.
      09-07-2011, 11:37 AM   #6
remmib
General
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
If you have e90 pre-lci, you can put on huge spacers in the rear, at least 20mm.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      09-07-2011, 03:16 PM   #7
wiseweasel
Drives: Fast!
thanks remmib... what's the max I can go? I love the fitment of my summer setup which is flush. Does anyone have good numbers for front and rear spacers on the stock 16" wheels? is it going to be like 15mm/25mm Fr/Re?
      09-08-2011, 12:21 PM   #8
Gary@TireRack
Moderator
369
Yes, tire options and better snow traction. To improve handling, you can use a more performance oriented winter tire like the Dunlop Winter Sport 3D or Michelin Pilot Alpin PA3.
Winter
