08-21-2011, 12:57 PM | #1 |
Rep 29
Too Wide Tires for 1M ?
The original 1M Wheels do well on high speed track with Michelin Sport CUP + on OEM size.
I have tried 18x10 with 265-35-r18 square and it drive nicely with R-Compounds. but My last wheel/Tire setup doesn't do the job overs 140kph. The car move sideways a bit, il Wooble, the stock suspension seems soft with this setup . I feel the car roling more than usual. I don't like the feeling ! i have tried pressures from 29to 40 without succes. help me ! The wheels a Lignt Enkei 18x10 offset 25, the tires are almost new Toyo R888 front: 255-35 rear: 295-30 What could be wrong ? Thank's |
08-21-2011, 02:38 PM | #2 |
183
Rep 3,939
Simple: you screwed around with the wheel-tire-suspension geometry that the M engineers designed for this car. Leave perfect alone. Not sure why people buy the 1M to change exactly what sets the car apart from a 135i...oh well, to each his own
08-21-2011, 02:56 PM | #3 | |
252
Rep 513
Why come to a forum that is largely here to support customization and thread crap? Would you prefer we all just sit around and talk about how identical our cars are? |
08-21-2011, 03:05 PM | #4 | |
183
Rep 3,939
1) The M division of BMW is more than about daily driving. There is a much more pronounced enthusiast twist to every car that ends up with an M badge on it. 2) The answer is not silly. Go ahead, hit the back button and see the multiple threads of people replacing springs, compromising a fully engineered M suspension in order to lower the car an inch. If you know anything about suspension geometry, then you know that this type of modification yields no performance improvement. 3) You can do whatever you want to your car....you have as much freedom to do that as I do to express what I think. Apparently your concern is not performance, it's individuality and making your car different from the next. 4) Yes there is always room for improvement, however, I can guarantee that the stock M suspension/wheel-tire package is more than enough for 99% of the people on these forums...gimme a break! 5) I don't "thread crap"...but if that is your opinion about my post, then you're welcome not to read it or digest it, trust me I won't be offended if you particularly don't read my posts. |
08-21-2011, 04:56 PM | #5 |
252
Rep 513
1. Agreed. There is still compromise built into the car. Regardless of M division it is still a mass produced car with limitations. Think clutch delay valve. Huge improvement without that!
2. Agree with lowering springs. But original post was about wheels and tires. 18 inch lightweight wheels likely would provide a performance improvement on the track. 3. An incorrect assumption. The items are not mutually exclusive either. One can individualize their car without sacrificing performance. 4. Likely true but again an assumption relative to the original poster whom you have no idea his abilities and needs. 5. No, I don't want to ignore your posts. I like differing opinions. But just didn't feel your response was necessary in this particular instance. |
08-21-2011, 10:02 PM | #6 |
79
Rep 1,421
OP, I'm a bit confused by something you said. You talk about a square setup and then finish by stating different tire sizes front to rear. You fit 295's in the rear? What size wheel are the 295's on? That's a lot of tire on the rear, and a lot on the front as well. On stock suspension you may be asking too much with the significant increase in grip. The sidewall on your 18's is going to be more compliant then the stock (somewhat stretched) 19's which could add to the floaty feeling also.
Dan Parker
08-21-2011, 11:13 PM | #7 |
Canada FTW.
184
Rep 519
What could be wrong? Putting 295 on a 1M. Hell, even a 997 4CS has 305 stock in the rear. Why would you do 295? Dan and Stud and perfectly right.
08-22-2011, 12:58 AM | #8 |
7906
Rep 11,785
Agree.. The answer is simple.. you went to extreme a setup...? Why did you get rid of a comfortable setup in the 265/35/18 on every corner to a setup so much wider at the rear? You will definitely increase rear grip, causing more oversteer, in a chassis that is already biased towards oversteer. I can definitely see that the car might tramline and definitely understeer on corner entry... with likely more oversteer from mid corner to exit. sounds like you should go back to the 265/35/18s.
08-22-2011, 02:16 AM | #9 |
Rep 120
08-22-2011, 03:30 AM | #10 | |
132
Rep 1,898
08-22-2011, 06:43 AM | #12 |
79
Rep 1,421
That's a problem. It isn't a simple question. Stiffer, lower suspension should help, in theory, but then you lessen the suspension travel.
Do you have any pics of the 295's on the rear?
Dan Parker
08-22-2011, 06:56 AM | #13 | |
102
Rep 677
Also... BMW equips their 1M safety car with 285 in the rear and 265 up front. If I were to go bigger(which I probably will) that is what I would go with. Again, M knows what they are doing. But if your vehicle is intended for show vs performance power to you. I personally will not mess with anything unless there is only substantial improvement, but again to each their own.
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
08-22-2011, 09:37 AM | #14 | |
118
Rep 898
Drives: '69 GT3, GT4, 1M, 912
Otherwise, this generally sounds like an alignment issue. You didn't lower the car or make any other changes that might have changed alignment? I think you mean understeer...
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
08-22-2011, 10:05 AM | #15 |
21
Rep 126
The reason I suspect he's running 295/30's is that with R888s, that's the only size he can run with his 255/35's to keep the tire diameter the same - in this case 25.1 inches. If you ran 265's with 285's on this tire, the front tire would be a larger diameter than the rear which would cause havoc with your stability control system as it would constantly think the rear tires were losing traction and the car would cut power to correct what it perceives as a traction problem. I'm currently trying to figure out best setup myself, also on 18's (9.5's & 11s), also for track use and as I have a sponsorship from Toyo, also on R888's. Agree at this point that on stock suspension your current setup may be a bit aggressive, but the custom wheel folks I've talked to thus far seem to think that with a good racing coilovers/camber plates etc, the setup you're running would indeed work. In fact, that is the exact tire set up CCW said they'd run as long as the 295's didn't have any clearance issues. Of course an easy option, would be to just run a square setup with the same tire all the way around (cheaper too). [we're doing some crazy power mods, that's why I want huge meat in the rear] I'm on my way to Piper Motorsports now, and have a call scheduled with Toyo and Moton this afternoon to discuss options so I"ll share what I learn. |
08-22-2011, 12:40 PM | #16 |
20
Rep 157
I've actually ran 265,275,285, and 295 on my Clockwork Orange. By far the best looking tires are 295. I had no rubbing whatsoever. The thing looked as beastly as could be. CHUNK!
However, NO tire size out of all those had the performance of the stock 265. Performance wise, it is by far the best size. Now I just run different sizes. 295 for meets, and 265 for everything else. I love showing off the car with the chunk. But I won't sacrifice the fun that 265 gives me for nothing. Just my 2 cents from my experience. |
08-22-2011, 10:31 PM | #17 |
Rep 29
the 295x30R18 on Enkei 18x10 offset 25
My suspension is stock and i forgot to try with a full thank of gaz if the problem is less severe. I have many set of wheels on hands -one set with OEM 19 wheels and OEM PS2: ok balance and low grip -One set of 19 OEM wheels and Michelin CUP + OEM size: ok balance, fair grip -One set of 19 OZ wheelsx10 and 265-35r19 square Hossiers R6: ok balance, great grip -One set of 18 Enkei 18x10 offset 25 rear 295x30r18 R888, 18x8,5 offset 38 front with 255x35r18 : bad balance on high speed, good grip and no more crasy oversteer. note: i am on a Canadian Toyo sponsership race program, and i woult like to find a fair setup with my stock 1M engine and suspension. Keep sending advices. Guy Last edited by guyp; 08-24-2011 at 08:37 PM.. |
08-23-2011, 05:09 AM | #18 | |
118
Rep 898
Also, if I understand it right you don't have issues with high speed balance mid-corner, more straight-line stability?
11-15-2011, 04:29 PM | #20 |
track Junkie
14
Rep 88
11-15-2011, 04:31 PM | #21 |
track Junkie
14
Rep 88
11-15-2011, 07:15 PM | #22 | |
450
Rep 1,358
Where did you hear that? A lot of people are wondering how wide we can go with a square setup. Also, at max width up front tire brand becomes important too. Not all 275/35s are created equal by a long shot. From what I've read on here so far that may be pushing it up front. Please if you have actual tried and proven data by all means share! Last edited by robertm; 11-15-2011 at 10:56 PM.. |
