FS - Springs for E92/E93 M Sport
08-03-2011, 05:26 AM | #1 |
28
Rep 636
NOW SOLD - Springs for E92/E93 M Sport
I have a full set of M Sport springs for an E92.
They are used and have only been 15,000 miles. They will lower an SE by approx. 20mm. Note: After a bit of research I have found out the following: They will lower the rear of any E92 SE model They will ONLY lower the front of any 6 cylinder E92 SE model (due to heavier engine) Rear spring labels = D2 Front spring labels = D6 £25 - very cheap Would prefer collection from Milton Keynes, but if necessary would post for around about £15 (very heavy item). They will come in a nice Eibach box Last edited by Boz335i; 11-22-2011 at 05:13 AM.. |
11-17-2011, 01:56 PM | #5 |
28
Rep 636
Wouldn't recommend for a 4 cylinder.
Rears would work fine, but front won't make any difference due to your lighter engine. I have updated the description with better info. |
11-17-2011, 03:13 PM | #6 |
26
Rep 412
hi mate, are teh e92 springs different part numbers to those of the e90?
if they fit the e90 i'd be very tempted and be first in line. cheers
Driving....330d SE
Gone to the stealers (i want it back )....130i Gone to the stealers....123d M Sport Coupe-BMWP 313 Alloys, BMWP CF Rear Diffuser, BMWP CF Spoiler, BMWP Black Grills, BMWP Pedals, Alpine Retrofit |
11-18-2011, 03:55 AM | #8 | |
28
Rep 636
If you go to the H&R website, then the part numbers are the same for E90 / E92. If you go to the realoem site, then they always say contact the dealer. So, I'm 99% sure these will work, if not I'll give you your money back. |
11-18-2011, 03:58 AM | #9 |
28
Rep 636
11-18-2011, 10:40 AM | #10 |
Rep 91
Im asking because I have an E92 SE and the front does look a bit high, I thought the E92's had sport suspension whether SE or Msport version bit obviously not comparing mine to Msports. Will your springs fit all models years? Mines an 07. If they will convert mine to Msport height I'll have them.
11-18-2011, 11:35 AM | #11 | |
28
Rep 636
If you go to the BMW configurator, and flick between the E92 SE model and the E92 M sport then the pictures give a pretty accurate comparison. I put Eibachs on mine with spacers, but total cost was over £500 (just to get the right stance for me, I must be bonkers), as I like the gap at the front to be about 10mm. I have removed the previous picture as it sits on a slope, so may appear lower at one end. This pic shows the car on flat ground, on 18"s without spacers, so fairest scenario. |
