HELP!!!
07-19-2011, 06:36 PM | #1 |
Rep 92
HELP!!!
So i just got a 335i and the other day i was went full throttle on the car and in 3rd gear around 6500 rpms a yellow check engine light came one but when i turned it of the light went away,so i tried it again full throttle and it came back on!!! I took it to the shop but what does it mean????
07-19-2011, 06:56 PM | #2 | |
40
Rep 406
Jason Premium, Sport, Stage 1 Eurocharged, OEM M-tech kit, DD CSL trunk lid, Smoked Blacklines, , Cyba 4 inch black chrome exhaust tips, Eibach Pro Springs, Koni FSD, Morr VS8.2 |
07-19-2011, 08:44 PM | #3 |
Rep 92
the only thing that came up was the half yellow engine light
07-19-2011, 09:11 PM | #4 |
40
Rep 406
Mine has never come up with the engine light, so I don't know. See what the shop tells ya.
07-20-2011, 09:27 AM | #9 |
10
Rep 426
Drives: 2008 BMS E90 335i AT
when mine had the same issue, they replaced some VANOS sensors to fix it. If you do a search, you'll find my post with all the info (it's in this forum section) and symptoms that I had. Depending on your situation, could be the same thing, but most people default with HPFP.
2007 JB e90 retired! 2008 BMS e90 stock for now |
07-20-2011, 09:53 AM | #11 | |
Rep 92
07-20-2011, 10:11 AM | #14 |
#Hashtag
10
Rep 245
07-20-2011, 10:20 AM | #15 |
Rep 92
07-20-2011, 05:31 PM | #16 |
Rep 92
07-20-2011, 07:40 PM | #17 |
Rep 48
Drives: 2011 328
If the high pressure fuel system is setting a fault (like a failed hpfp), the wastegates are held open so no boost can build up, therefore the engine wont go too lean. Probably something in the high pressure system due to being at higher rpm's
07-20-2011, 07:42 PM | #18 |
798
Rep 4,784
I smell boost leak somewhere.. might be wastegate, maybe blew off a boot or pipe somewhere down the line. happens to my friend all the time
ERnie
2016 BSM/f80/ZCP |
07-21-2011, 09:35 AM | #21 |
10
Rep 426
I"m sure it's fixable, nothing too serious. What shop did you take it to?
