Sirius Retrofit
07-09-2011, 09:10 PM | #1 |
Rep 87
Sirius Retrofit
I have an 07 with idrive and just added the the Sirius module.
I changed over the MOST bus connections so its in the loop. I added $655 to the VO in the CAS module and one other (can't remember which one right now) with ncsexpert. The sdars option was already set to not active. I am able to access SAT with idrive, it shows the stations, but whenever I try to change them it says to call Sirius - I did and they said they sent an activation signal -its still stuck on ch012 ThePulse with no audio. Did I code it incorrectly or is the module bad? |
07-10-2011, 12:25 AM | #3 |
Rep 87
How do you delete it from the VO? The way i know how to add, doesn't have a remove button.
edit: figured out to remove. and sdars is active, no difference. Last edited by wickedgtr; 07-10-2011 at 12:31 AM.. |
07-20-2011, 04:32 AM | #5 |
Rep 87
Well, great news! Finally got it to work, after the 8 or 9th call to Sirius, I got a tech that knew what was going on, -- it appears the original customer-service rep incorrectly provisioned my radio -- everything is working great now!
08-03-2012, 10:10 AM | #6 |
NeedsMoarBoost
42
Rep 528
does anyone know if the older sirius modules will program into the car at BMW? Or do you NEED the newest one?
08 135i 6m - 12.1@120.2 2.0 60ft - JB4/Meth - SOLD
09 335i e92 Mtech - RB FBO |
