Technic Harness Wanted
07-07-2011, 03:25 PM | #1 |
344
Rep 6,176
Just eagerly waiting for all the parts to come through the post so wondering if anyone has TECHNIC's harness for sale?
Get In Touch.. |
07-08-2011, 07:09 AM | #3 |
96
Rep 831
Did you try VP Electricity?
F31 335d M Sport XD - Mineral Grey - Coral Red - 19" 442M - HK Audio - M Sport Plus Pack - Heated Seats Check out my E90stereo install guide - http://www.e90post.com/forums/showthread.php?t=540954 |
07-08-2011, 07:51 AM | #5 | |
344
Rep 6,176
I did but he's not responded :-( been a few days.. I'm happy to call him too, but don't know any relevant numbers
Much appreciated! I am also looking for.. 1. Under Seat Jumper Connectors for my SWS Subs 2. 2 or 4 x OE Speaker Adaptors 3. SWS Spacers (contacted JTSherri but no response either unfortunately ) I'm upgrading from stock (non idrive / non L7) to Focal KRS 100 and SWS subs + possibly rear deck speakers (hence requiring an extra 2 OE spkr adaptors) and need the above plus Technic's harness to do the job Ready to buy for anyone selling these, holla. |
07-08-2011, 09:42 AM | #6 |
96
Rep 831
Hey AWBimmer
The harness is the main thing thats going to halt proceedings, if necessary you can make the OE Speaker adapters using the BMW part numbers in my guide. They will cost you about £10. The jumpers can also be fabricated so no biggy. If you get no joy with the spacers you can use MDF. I think I've got a template somewhere I could email over
07-08-2011, 11:23 AM | #7 |
Rep 463
I have been in touch with VP - technic is out of harnesses until August.
So here's the deal on harnesses: Technic has a harness design that plugs into the back of the stock head unit and brings out front and rear speaker signals, and remote turn on. He is out of it until the first part of August. We have been making a harness which plugs into the underseat woofer connections, and brings the front output speaker wires and the door input speaker wires into the trunk, along with wires for the underseat woofers. This works very well with our base Stereo upgrades, since we leave the stock rear speakers alone (rear speakers help very little and are, in my professional opinion, a waste of your money). We split the harness so that you are taking the signal to the inboard of the L R wheel well location - where we put the Clean Sweep - and the woofer and door speaker wires to the OEM amp location (near the LR tail light). If we are using our Zapco DSP amps, we run all the signal and speaker to the same corner. So we sell technic's harness when it's available - usually as part of our packages, and we forward inquires for just the harness on to technic directly (you may have already heard from him). I don't know if our harness would be of any use to you or not. Our harness does not have a remote turn on wire and we depend on the JL CleanSweep or a RTO signal-sensing widget. In general, we sell packages, not parts. We do have SWS woofers, and we could put together a package with two woofers, rings and gaskets, and the harness we discussed above for $435 with front door speaker rings thrown in. I was looking to do exactly the same for the front door and subs. |
07-08-2011, 12:47 PM | #9 | |
96
Rep 831
I did it myself. You can see have a look at it using the link at the bottom of my signature
F31 335d M Sport XD - Mineral Grey - Coral Red - 19" 442M - HK Audio - M Sport Plus Pack - Heated Seats Check out my E90stereo install guide - http://www.e90post.com/forums/showthread.php?t=540954 Last edited by B33M3R; 07-08-2011 at 12:58 PM.. |
07-08-2011, 01:08 PM | #10 |
363
Rep 5,984
Have you considered the Blaupunkt harness?
It pretty much does the same thing. It plug in the back of your head unit and gives you audio in and audio out, either on a 2m version or a 5.5m version to take to the boot. You can either loop the rear channels back into each other or amp them too. It can be had for around £60 on line, not sure how that compares? I think Technic designed his originally as Blaupunkt stopped selling theirs in the US, however still available over here. |
07-08-2011, 01:23 PM | #11 |
Rep 463
07-08-2011, 02:03 PM | #12 | |
96
Rep 831
A decent installer will likely charge you a good £300 + labour, maybe more for a simple amp and amp and speaker swap which would in some cases cover the whole cost of you're equipment! Be brave!
07-08-2011, 02:05 PM | #13 | |
96
Rep 831
Just wandering does the Blaupunkt harness have a remote feed as well?
07-08-2011, 03:00 PM | #14 |
363
Rep 5,984
Hmmm? Can't remember.
I think so as you can just use that and not even attach to teh battery (recommended for the smaller 2ch amp only). However, if not you could use the 12v out as a remote feed and wire your amp to the battery, which I think most would do anyway. This would work well as it would turn the amp on as soon as you unlocked the car and then send it to sleep 16 mins after you lock it when the car goes to sleep. Would stop the annoying thump you get with most amps where the amp cuts in after a signal is sent to the inputs. |
07-08-2011, 03:16 PM | #15 |
96
Rep 831
Cheers
07-11-2011, 04:15 AM | #16 | |||
344
Rep 6,176
1. Underseat Jumper Connectors 2. 2 x OE Speaker Adaptors.. Sorry B33M3R, where did you say I can get hold of these from please? After this, just need my line out converter, gain control remote and some cables and I’ll set to go!! Wooo!! Thank you! |
07-11-2011, 04:20 AM | #17 | |
Rep 85
http://www.e90post.com/forums/showthread.php?t=550895 |
07-11-2011, 09:29 AM | #18 | |
344
Rep 6,176
Thanks for that. I saw the ad as well. I have now bought the harness, but thanks still. |
07-11-2011, 02:37 PM | #19 |
Rep 85
07-15-2011, 06:07 PM | #21 |
344
Rep 6,176
Not sure what that cable is bud sorry.. any more info perhaps on it?
07-15-2011, 06:32 PM | #22 |
363
Rep 5,984
Well it is a cable that has daisy chains the head unit and oem harness and plugs into the parrot kit, so the speaker signals and power are routed via the head unit, but thinking about it you could just chop the cables for the speaker signals and run some RCAs to them, giving you a nice harness to add an amp and routing the cable back to the speakers without butchering the oem cabling. Which I am presuming is what Technics harness does?
Here is a pic... It gives you speakers out of the head unit and then back in again, and 12v switched to turn on the phone kit, but would also turn on an amp. The speaker connectors are standard iso connectors, and you can buy 5m extensions for around £10, you would need two, one to the amp and one back out again. But you are looking at around £30 all in. I cut the oem harness last time I put an amp in, but this would be completely plug and play, and all for around £30. |
