LED reliability
06-15-2011, 04:08 AM | #1 |
33
Rep 918
LED reliability
Posted this topic on the Technical forum but no response, so in case it was missed I'm posting it on here.
How reliable are the replacement LED's for e90 lci angel eye halogens, or any retrofit headlamp LED's for that matter? I suppose they're made in China like most things these days, and I'm not saying that's a bad thing - but - there is also a lot of substandard shite coming out of China and sold on by UK retailers. Just don't want to be under the car changing LED bulbs more than I need to - plus they're not cheap to buy! Last edited by Cyprio; 06-15-2011 at 04:13 AM.. |
06-15-2011, 05:17 AM | #3 | |
33
Rep 918
I know there have been a few people on here who have experienced duff LED's and it would be good to know who to avoid when purchasing. |
06-15-2011, 05:21 AM | #4 |
1867
Rep 13,043
Drives: BMW M340I G20
How long's a piece of string? It's like asking how long will a bulb last. as per Panda, they tend to last a lot longer than bulbs.
06-15-2011, 05:23 AM | #5 |
1397
Rep 8,083
Whilst the LEDs themselves will outlast a conventional incandescent bulb by a considerable margin you have to remember that an LED "bulb" comprises of 10 or so individual LEDs encapsulated in a housing, with current limiting resistors and possible a bypass resistor to cancel bulb errors. It's the quality of this housing and sub-assembly that matters. Saying an LED has "10x the life of a halogen bulb" is too simplistic.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
06-15-2011, 05:40 AM | #8 |
1867
Rep 13,043
I've yet to see a failed LED, the ones we had fitted in our kitchen have been running for ten years, without a failure, unlike the G9 bulbs installed at the same time, which have failed many times
06-15-2011, 08:10 AM | #11 | |
33
Rep 918
Anyone else purchased angel eye LED's from ebay or wherever, and then felt they were sub-standard build quality, so I can avoid buying from them? I'm just trying to determine where I can buy a good quality pair from. |
06-15-2011, 08:13 AM | #12 |
1867
Rep 13,043
I fitted a set to my 335i and found they interfered with the radio reception. Something well documented on this forum.although not all member found the same.
06-15-2011, 10:34 AM | #13 |
Rep 257
Drives: 320i M sport plus
I bought a set from fleebay , very poor quality indeed , (china = Dodgy electrics )I never did fit them and sold the car eventually
06-15-2011, 10:45 AM | #14 |
33
Rep 918
06-15-2011, 11:00 AM | #15 | |
54
Rep 2,197
The problem is general crap quality of LED lights you buy online. |
06-15-2011, 11:01 AM | #16 |
1867
Rep 13,043
06-15-2011, 11:06 AM | #17 |
253
Rep 7,089
Drives: '06 AW 330xi
If an LED is designed right, it will last for 10+ years.
However, the plug and play units you see have small heatsinks. They are ok for short distance driving, but once the engine bay starts getting hotter and ambient air around the bulb increases, efficiency goes down. It doesn't help that there is no airflow either....since they are housed inside the headlight. LUX does include a fan and this is best design there is. (For the E90 at least, not sure what the E92/3 bulbs look like). But it can only do so much in an enclosed space. If you guys want help designing a bulb yourself, PM me. |
06-15-2011, 11:11 AM | #18 | |
33
Rep 918
06-15-2011, 12:03 PM | #19 |
199
Rep 3,500
I take it that you've read this discussion?
Seems that this kit may be the answer as it is said not to create any fault codes or interference. http://www.e90post.com/forums/showthread.php?t=540404 |
06-15-2011, 12:05 PM | #20 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
The sourcing from "china" is not the problem, its that there are good manufacturers from China and there are sub par ones. To the naked eye you want know which is which. Buy from a trustworthy vendor with a warranty in place.
If the price is too good to be true, its probably on the poor side of quality. |
06-15-2011, 01:50 PM | #21 | |
33
Rep 918
06-15-2011, 02:58 PM | #22 | |
1545
Rep 8,970
I've had two OE BMW rear LED light clusters replaced under warranty. On a 2 yr old car. Not the LEDs' themselves, but water corroding the tracks inside the enclosure causing individual LED elements to go out. |
