The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Squeeky fan in E91
      06-09-2011, 02:58 PM   #1
F31-340i
F31-340i's Avatar
156
Drives: BMW 340i Touring
Squeeky fan in E91
I have a noisy aircon fan. Squeek is proportional to fan speed, and is noisier under braking.
Sounds like the bearings in the fan are shot.
So -
a) where / how much for a new fan?
b) how big a ball ache is it to replace? I've got the "replaced an E46 hedgehog" medal, but hoping its easier than that!
If someone could post some snapshots from TIS that would be great - my copy no longer works on 64 bit Windows
340i F31
      06-09-2011, 03:30 PM   #2
jinjur
yes....spelt with J's
jinjur's Avatar
55
Drives: F31 325D MSport
1. Pollen filter out
2. WD40 and associated straw
3. Spray at the rusty fan centre for a bit
4. Let it soak in
5. Enjoy a silent fan and a pish *rotten smell in your car
* i like it though
Worked for me
      06-10-2011, 07:50 AM   #3
Dr Dave
Zummerzet Zyder Drinker!
112
Drives: '06 330D Le Mans Blue
As he says.....^ will work a treat and cost nothing.
      06-10-2011, 12:46 PM   #4
F31-340i
F31-340i's Avatar
156
4. Let it soak in
* i like it though
Worked for me
Thats a good idea. Thanks. I take it the smell goes away quickly?!?
340i F31
      06-12-2011, 04:14 PM   #5
F31-340i
F31-340i's Avatar
156
Top tip Jinjur - thanks!
Worked a treat.
Pics:
1. Mircofilter removed - 6 x 8mm hex bolts (how dealers dare charge more than £30 to do this (inc parts) beggars belief).
2. Zoom in on right hand vent
3. Further zoom (red box shows next picture)
4. Here you can make out the fan behind the vent - complete with rusty bolt in the centre. Quick squirt of WD40 through its straw straight onto the fan. I had the fan on high speed with all the windows open.
Smelled a bit, but WD40 doesn't smell too bad. After 1hr or so driving, hardly smells at all now.
Most importantly = NO SQUEEKING! Result.
340i F31
      06-12-2011, 04:32 PM   #6
willhollin
willhollin's Avatar
England
268
Drives: VW T5
I'd have used white lithium grease, WD40 is very thin and won't last long.
      06-12-2011, 04:51 PM   #7
F31-340i
F31-340i's Avatar
156
I'd agree - but access is not really very good - look at the first pic - that fan is really buried. I'm not sure its really the rusty bolt bit that is the issue - I think this works as the WD40 is able to penetrate a number of bits of the fan assembly.
PS when does your 1M arrive?
340i F31
      06-15-2011, 05:25 AM   #8
jinjur
jinjur's Avatar
55
Hey Will....
I think WD gives it all it needs tbh....I dont think lithium grease would penetrate as well either although if you could actually get at it, lithium would probably be better.
And another Jinjur top tip, I naffled 3 of the wee straws that you get with WD40 and used heat shrink to connect them together to give a reach of about 35 or 40 cms.
Makes it much easier and also is easily reversible.
I did mine about a year ago and still no squeaky deeky
J
      12-15-2011, 10:50 AM   #9
sixpot
19
Drives: BMW 335i Coupe
Will have to give this a bash, as mine is driving me nuts! (seems worse on lower fan speeds and when braking like mentioned above)
      12-15-2011, 12:24 PM   #10
F31-340i
F31-340i's Avatar
156
go for it.
it only takes 5 minutes - and when you do it you'll think - "I wish I had done that months ago!"
340i F31
      01-30-2012, 12:04 PM   #11
EQUANT
28
Drives: 320d
Just noticed this noise in my car today. It's present when cold, at low fan speed (goes away if speed is increased) and under braking.
Will execute the WD-40 procedure asap. Did you spray the WD-40 while fan was turned on or off?
BMW 320 dA LCI, BMW PPK - 197HP, 2010, sapphire black, steptronic
      01-30-2012, 02:12 PM   #12
penport
Surgeon General
Drives: F32 435dx
Did mine the other day - with the fan on - couldn't find a tiny WD40 straw so just sprayed it straight from the can in the general direction of the rusty bit - worked a treat
      01-30-2012, 02:46 PM   #13
EQUANT
28
Drives: 320d
Just got out of the house and did it to mine, also. I sprayed with the fan off, using the thin straw from WD-40 spray can. Then i started the fan for a few seconds, stopped and sprayed some more.
So far it seems to have worked, but i will wait until tomorrow when it will be frozen again (-20*C announced tonight )
ps: mine also had the rusted bolt in the center, although i noticed it had some sort of 'cover' over that part (probably to avoid water from pouring directly on the bolt). Don't think the actual bolt is the problem; more likely the motor shaft/ shaft sleeve + slight rust on them.
      01-30-2012, 10:15 PM   #14
sixpot
19
I ended up taking the whole fan assembly out from the dash so I could get some spray chain lube onto the bearing.Hopefully this should keep any water from re-entering it.
Put a couple of squirts of plus gas in it first mind to stop the squeak.
Job took about 30 mins, so not too bad, and because you are spraying right onto the bearing itself. And not the fan itself, hardly any smell could be noticed on start-up.
      02-01-2012, 01:34 AM   #15
EQUANT
28
Drives: 320d
Well, noise is gone now. That was easy enough to do.
Thanks for the good info guys!
      01-28-2013, 05:24 AM   #16
magic77
magic77's Avatar
258
Drives: ex- 335i
Worked a treat used some GT lubricant as smells not as strong as ED40 and on low speeds its now silent
F30 335i M Sport - now departed
      01-28-2013, 05:51 AM   #17
Brian mc21
Brian mc21's Avatar
No_Country
39
Drives: E91 320d M Sport
Are you talking about lubricating the fan on the car or your nether regions Will.
E92 330D LCI
NSR 250 MC21, CBR 600RR 3
RVF400
      01-28-2013, 03:38 PM   #18
335DEE
335DEE's Avatar
England
38
Drives: M3 DCT
for my trick , i used a longish screwdriver and some 3-in-1 oil . Place screwdriver on rusty bit you want to lube , squirt oil onto screwdriver shaft , let gravity take over. Jobs a goodun
      01-29-2013, 12:59 AM   #19
sixpot
19
I like that!
      07-10-2013, 02:41 PM   #20
corasdad
corasdad's Avatar
24
Drives: m sport 320d
just tried the wd lets see
      07-10-2013, 04:41 PM   #21
Steed
Drives: E91 2009
This is a great Forum, I almost want mine to start making a noise so that I can fix it!!
      03-02-2014, 07:17 AM   #22
koches
44
Drives: 2009 328i xDrive
Going to give it a go! This damn fan! Thanks men!
