TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Fog Lights with AE DRL? (No Low-Beam?)
      06-08-2011, 03:45 PM   #1
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
No_Country
36
Drives: 2010 Toyota FJ
Thought I had found the value to allow for me to turn on the foglights when only AE DRLs are on with the switch set to Auto without the low-beams coming on. However it didn't work.
Does anyone have some input on this?
Would like to be able to roll with just my AE's on with the fogs.
Cheers!
      06-09-2011, 08:07 AM   #2
Thunder Dump
That tickles
Thunder Dump's Avatar
Drives: '09 328i E93 SGM/CR
Cheers!
I know with my '09 if I put the switch to parking lights only, I can run just the fogs/parking lights with the AE DRLs. No low-beams needed. And no coding needed--that's factory setup.
EDIT: Saw you wanted to do this in the Auto position. Just pointing out it can be done manually without coding.
      06-09-2011, 10:44 AM   #3
Imperator
Imperator's Avatar
52
Drives: 2010 E92 335i
+1 and activating Euro corners will essentially achieve the same results once the switch is in the 'Parking lights' position.
      06-09-2011, 12:09 PM   #4
CasperSYTFU
SYTFU Crew
No_Country
36
Thanks guys but yea I already know about that and have the corner deletes. But I want the functionality of being able to have my fogs on for looks with the DRL but then in low light situations it would turn my headlamps on. Think it would be a really nice little option to have.
      06-09-2011, 12:17 PM   #5
MikesBMW
318
Drives: X3 M40i
2019 BMW X3 M40i  [0.00]
2017 BMW X1  [0.00]
also interested in doing this
      06-12-2011, 02:17 PM   #6
Elliott@DetailAddict
300
Drives: E90
Any updates?
      03-15-2012, 11:51 AM   #7
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
To have foglights on as DRL along with your AE (assuming you have AE set as drl) only, do the following in you NFRM module:
DRL_TFL_MIT_NSW
nicht_aktiv --> change to "aktiv"
PWM_NSW_TFL
wert_01--> change to "wert_02"
This way, your fogs turn on as you drl along with your other drl lights (AE). It does not show on your cluster that they are on.
When you move the switch to your lowbeams, they shut off (can be toggled one via the foglight button, like before)
      03-15-2012, 01:50 PM   #8
300
Drives: E90
Desi I owe you a beer!
      03-15-2012, 02:32 PM   #9
DESI4life10
201
Anytime bro :-)
Sending you a PM.
      03-16-2012, 01:50 AM   #10
bmw325i
223
Drives: 2006 BMW 325i
DRL_TFL_MIT_NSW
PWM_NSW_TFL
I want to have my foglights on all the time (at least at night) would this do that.
      03-16-2012, 07:35 AM   #11
DESI4life10
201
If you read my post. This is for fog to come on auto when drl are on. So you can roll with drl on at night as well if you want and the fog will still be on.
There is another line to code if you want them on auto when your lowbeams are on. I believe grant has created a thread regarding that matter.
which is right here: http://www.e90post.com/forums/showthread.php?t=614274
      03-18-2012, 11:58 AM   #12
Broendbjerg
Member
No_Country
Drives: BMW E91 320d Touring
Does anybody know if it is posible to do the same with an old FRM module (FRM1 i assume?).
I can't find anything related to DRL in the trace file. See attached file for reference.
Is it possible to get working, or do I need to upgrade to FRM2 or 3 and at the same time have welcome lights and so on?
If not exactly clear I want the light switch to stay in the auto position and have angel eyes and my fog lights on when driving at daylight. At night my xenons should automaticly switch on.
/Broendbjerg
      03-23-2012, 10:47 AM   #13
JimVR4
JimVR4's Avatar
338
Drives: 21 X5 M50i M-Sport
DRL_TFL_MIT_NSW
PWM_NSW_TFL
I coded this and it does work however I get an external lighting warning (yellow circle symbol) on my BC. With Tool32 I was able to read the errors in German and I ran that through google translator:
E R R O R M E M O R Y
Date: 22.03.2012 20:29:54
ECU: FRM_70
JobStatus: OKAY
Variant: FRM_70
RESULT: 3 error in error memory !
A8C5 daytime left broken
No signal or value
Test conditions are met
Error currently exists and has already saved
Error would not cause a warning light flashes
Error code: A8 64 C5
A8C6 daytime right faulty
No signal or value
Error currently not available, but already stored
Error code: A8 C6 24
A8A8 beam cornering left or defective
No signal or value
I think the last error is stored from when my headlight was broken and replaced. I've coded NFRM back to defaults for now. When I get a chance I will try to clear error memory using Tool32.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      03-23-2012, 10:55 AM   #14
DESI4life10
201
I ran this for a week and never had any errors. Might be specific to your car setup then.
      08-12-2013, 11:25 AM   #15
Red_Bean_Bun
62
Drives: E92
Guess its not possible on frm1 ?
/Broendbjerg
      03-14-2014, 02:13 PM   #16
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Bumpity bump to the top we go
I'd also like to know if this is possible on earlier models?
I have a 02/2007 e92 335i
      11-30-2015, 01:58 PM   #17
DestinationKnown
Russia
Drives: E81
Got the same problem after adding "DRL_Tfl_Mit_NSW>aktiv and Pwm_Nsw_TFL>wert_02". Yellow warning and a8c5/a8c6 errors.
All warning and errors disappear if revert back NFRM config and clear stored errors using INPA. My FRM version is FRM2_E89.C09.
Please help!
      11-30-2015, 11:13 PM   #18
JimVR4
JimVR4's Avatar
338
Please help!
I never got this working and my cable died long ago.
iStep 03/2023.50
      12-01-2015, 04:40 AM   #19
DestinationKnown
Russia
Drives: E81
I finally managed to escape yellow warning problem and was able to code fog lights as DRL. To do this I disabled all cold/warm checks and now it works as expected (I double checked all light bulbs - everything is ok).
But overall I didn't get what I wanted - I thought fully automatic fog lights will work with LH_UND_NSW_NICHT_GLEICHZ option (front fog lights not simultaneously with flash-to-pass), but it won't
