TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      06-03-2011, 09:49 PM   #1
northern2020
northern2020's Avatar
44
Drives: '11 X5 M / '01 B5 S4/ 15 328d
KW V3 coilovers EDC termination modules?
KW V3 coilovers with EDC termination modules-
Has any X6M owners done this coilover kit yet?
Looks pretty sick as you can fully drop with dampening and rebound control.
Planning on doing this on my X5M but only know of one fellow who has done this.
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
      06-05-2011, 04:35 PM   #2
DK35
DK35's Avatar
92
Drives: The MONSTR
2010 X6 50i  [9.34]
I'm looking into this for my 50i. Looking at the full hydraulic system. Getting pricing from my installer this week.
      06-06-2011, 09:41 PM   #3
northern2020
44
Let me know how you like it...so little out there for performance suspension
      06-07-2011, 04:56 AM   #4
XRQTOR
Drives: 2008 X5
What sort of coin they asking for this setup
      06-08-2011, 09:04 AM   #5
mgakathereaper
Drives: 2011 X6M
I will be watching this thread with interest as well. I currently have the H&R 2" drop package and the look is perfect but the ride is a bit rough on Cleveland, OH roads. Of course low profile run flats dont help either but I suspect KW V3 would still soften the blow of minor pavement imperfections. I would not want to drop it any lower but if I could gain some "comfort" and additional handling I would definately consider the option. It looks like they have a daily driver option called the "KW Street Comfort" but this would sacrafice some handling aspects. I will be doing some research for sure.
      06-08-2011, 09:27 AM   #6
mgakathereaper
Drives: 2011 X6M
So I spoke with KW...
Basically they only have the KW V3 for the X6M so that is the only option. They only sell as a package so it would replace both front and rear shocks/springs. The rear would still give you the linkages for leveling and the max drop would be 1.4" from factory. The fronts would give a max drop of 1.8". In general, the package would give some additional "comfort" depending on the configuration and would come in somewhere between stock ride and H&R 2" sport springs. Handling would be improved but you will loose EDC functionality. Basically you would just have to dial in the coilovers to your liking but it wont be on the fly like EDC.
I will need to noodle on this for sure.
      06-12-2011, 08:35 AM   #7
Bob MG
Moderating
Bob MG's Avatar
United Arab Emirates
418
Drives: like a muppet
http://kw-store.com/products/complet...5-m-w-edc.html
      06-27-2011, 10:38 PM   #8
northern2020
44
Originally Posted by Bob MG View Post
Ordered!
      07-29-2011, 10:18 AM   #9
mgakathereaper
Drives: 2011 X6M
Any of you guys get these installed yet? I was ready to pull the trigger a couple weeks ago and found out lead times are like 4 weeks. I suspect you guys are still waiting as well.
      07-29-2011, 01:43 PM   #10
northern2020
44
Still waiting I was told July-1 but have not received as of yet!
      07-29-2011, 03:20 PM   #11
mgakathereaper
Drives: 2011 X6M
Thanks. I figured I wasnt the only one in the holding pattern. Hopefully worth the wait.
      07-29-2011, 03:39 PM   #12
Bob MG
Moderating
Bob MG's Avatar
418
Mine are at IND awaiting shipment with all my VRS stuff and frozen silver wrap
      07-30-2011, 09:22 AM   #13
mgakathereaper
Drives: 2011 X6M
Nice. That frozen silver wrap could be interesting. Are you doing a full wrap? I had dabbled with doing a Satin/Matte black at one point but never made the jump.
Looks like Dinan now has a suspension for the X6M... Not an aggressive drop at 3/4" but I am sure the ride is much "smoother" if thats a priority for anyone. Handling might not be as good as the KW's but everything is a compromise.
http://www.dinancars.com/shop/D190-7...it.aspx#page=1
      07-30-2011, 11:11 PM   #14
northern2020
44
Found out mine will be in this week.
Kinda 50/50 on the install, may wait till next summer, or sell...
I want a faster garage queen.
      08-03-2011, 01:54 PM   #15
northern2020
44
Received, now awaiting install
      09-04-2011, 08:26 AM   #16
Bob MG
Moderating
Bob MG's Avatar
418
fitted mine
Much better ride than I had with the H & R 1,5 inch drop springs and linkages
The drop is also more than with H & R
I could go lower but I reckon this is the most one should drop a truck.
When you fit these you must ensure that the front shock sits as low as possible in the mount, which is lower than the OEM shock sits. If you don't do this you will raise the shock 25mm higher and will not be able to adjust the suspension low enough to the min spec KW allows.
I did this the first time and I was bottoming out on the bump stops.
      09-04-2011, 11:34 AM   #17
mgakathereaper
Drives: 2011 X6M
Bob MG
Nice! The wheel gaps look about perfect for the truck. When you say its a better ride, do you mean comfort, handling or all of the above?
I actually have the 2" H&R drop so if you are getting improvements over the 1.5" then I suspect I would notice as well if not more so.
I wish the lead time on these coilovers wasnt so long...
Truck looks great. Are you still thinking of a vinyl wrap?
      09-07-2011, 02:45 PM   #18
Bob MG
Moderating
Bob MG's Avatar
418
Bob MG
Bro call Nate at IND. he hooked me up with 2 sets in a matter of days!
I scrapped idea of wrap as I didn't want to change cars colour. Maybe I go matt White soon.
Ride will always be better with a coilover vs a spring as the shock is matched to the coil.
Feels firm but doesn't bounce and send terrible shock waves through car when you hit a bump. Plus you will be able to drop as much if not more than H&R 2 " drop.
Mine are set to 430mm from centre of wheel to fender. KW spec min is 415mm so I could drop another 15mm and still be within spec
      09-08-2011, 01:37 PM   #19
mgakathereaper
Drives: 2011 X6M
Bob MG - Thx for the info. I placed my original order about 6 weeks ago with another distributor but I might cancel and start over with IND since I have dealt with them in the past. Maybe stock has improved over the past month.
Good to know about ride improvements. I would definately like to calm the bounce and the harsh bumps. I will take note of your settings as I tweak to my liking.
Thx for sharing.
      09-08-2011, 01:55 PM   #20
Bob MG
Moderating
Bob MG's Avatar
418
I lowered it another 10mm
I can get about 2 and a half fingers between tire and fender on fronts (420mm from centre wheel to fender) and slightly more for rears (about thee fingers)
Ride no different Yay for coil overs!
      11-20-2011, 10:10 PM   #21
Boosted-M
37
Drives: F10 535D XDrive (USA)
I had the H&R 1.2" Lowering springs and did not like the bounce in the rear and the hard slam you would get when hitting a good bump or pothole.. Put the stock springs back in the car for now...
So from your posts it sounds like these Coilovers do provide a much better ride quality? I wanted to be sure before getting another lowering kit..
      11-21-2011, 09:36 PM   #22
northern2020
44
[QUOTE=Boosted-M;10841148]I had the H
