TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 335d engine cover removal
      06-02-2011, 01:33 PM   #1
Billyray911
Billyray911's Avatar
Venezuela
197
Drives: Blah
It's time for fitting my crd-t tuning box on the 335d.I've only had it lying about for a few months!
I've had a look and there are five hexagonal bolts that need removing.
The main problem looks like the rear right bolt which is hidden.
What tool are people using to take the cover off?
I have searched but I'm getting mixed messages.Some are saying to just pull the cover as they are only push clips.However,they do seem to be proper nuts requiring a proper tool (not me!).
Cheers in advance...
      06-02-2011, 03:50 PM   #2
acerboo
England
179
Drives: e92 335d lci
you need a star screwdriver bit to take out the 5 bolts but you need to remove the black plastic cover along the base of the windscreen otherwise you cant locate the cover back on properly you aslo need to remove the oil filler car and its best to put a clean rag in the hole to prevent anything unwanted falling in!
      06-02-2011, 04:46 PM   #3
Billyray911
Venezuela
197
Drives: Blah
Thanks for the advice-appreciated.
Have been looking at male torx head sets-any idea of the size and il just try and find the specific part?
      06-03-2011, 01:22 AM   #4
JonnySi
BMW Technician
JonnySi's Avatar
Drives: BMW
They are a 5mm allen bolt, and on a 335d you dont need to remove the microfilter housing.
      06-03-2011, 06:18 AM   #5
briers
Ben
briers's Avatar
62
Drives: Tesla p85d
Like Johnny said for the head size
Remove the plastic casing for the tubes at the back. Lid pops off easily then push your nail into the grooves of the 3 bottom clips and if will come free. Then I use a flexy screwdriver bit to get the remaining screw out. Then just carefully slide the cover forward
      06-03-2011, 06:25 AM   #6
briers
Ben
briers's Avatar
62
Drives: Tesla p85d
And no they certainly aren't push clips.
As acer said, oil filler needs to come off. Take it off, lift the cover and screw back on before removing last bolt
      06-03-2011, 07:27 AM   #7
Billyray911
Venezuela
197
Drives: Blah
Thanks guys-appreciated!
      06-03-2011, 11:47 AM   #8
acerboo
England
179
i took the microfilter housing off because berfore i did that i tried to fit the engine cover back on and it rucked up the sound deadening and it rattled like hell the only way i could stop it was to remove micro housing so i could place the engine cover from above, just my experience.
      06-03-2011, 12:31 PM   #9
Billyray911
Venezuela
197
Drives: Blah
No,thanks for letting me know.I find it's best learning from others experience / disasters!
