Sunroof Smell?!
05-31-2011, 03:29 AM | #1 |
17
Rep 138
Sunroof Smell?!
Strange as this may sound, but I get a nasty smell when I open my sunroof! - Its only when I perk the roof up (not open full).. Its nothing to do with the AirCon/Vents.. Ive tested this for some time, and have came to the conclusion either im going mad or the sun roof smells..lol
Ive tried halfords air con cleanner and still no joy, any ideas what this could be?.. ive read online (google search) that possibly something to do with the headliner?? - anyone had this before? car is 100% when the roof is closed or even open full. Not a nice odor at all when you have passangers |
05-31-2011, 03:36 AM | #2 |
1042
Rep 6,946
Is there some dirt and gunge in around the sunroof aperture, that bit never gets washed and maybe just needs a good clean, also around the edges of the aperture and the sunroof itself.
05-31-2011, 03:39 AM | #3 |
17
Rep 138
I had a look inside Davey and cant see anything.. there is a mould around the outer glass part, Definately going to get this cleaned see if it makes a difference.. the smell is like sh*te!..its bad mate..lol
05-31-2011, 04:06 AM | #4 |
337
Rep 1,660
Have a look to see if one of the roof drains is blocked - if it is gunged up, the smell could be coming from there. Locate the drains then carefully pour water down them to check for blockage (mind your feet - they may get wet!)
Mike |
05-31-2011, 04:34 AM | #5 | |
17
Rep 138
I couldnt see any drains etc when the sunroof is open Mike, should it be visible when the roof is open?? Thanks |
05-31-2011, 05:12 AM | #6 |
337
Rep 1,660
You should see the drains - I haven't got a sunroof so I can't tell you where, but have a look in the front corners, that is the usual place, with the drain pipe routed down the A-pillar - hence the comment about wet feet - you pour the water in the top, and as you are standing close to the car, it comes out just where you tend to stand. If one is blocked, the other will probably be free enough to take the water away.
