Where is tachometer signal wire?
03-29-2007, 10:31 PM | #1 |
Love my car!
Rep 78
I'm installing a data logger and need to access the tachometer signal. Does anyone know which wire is the tach signal? Under the dash is the best access point for me.
Thanks!
2018 M240i xi (LCI) | Estoril Blue | Dinan Stage 1
03-29-2007, 10:35 PM | #2 |
United States Marine
319
Rep 2,748
There is no "tachometer" signal. It's all bussed information on a single signal wire. You're not able to access the tach info!
03-31-2007, 10:13 AM | #3 |
26
Rep 1,826
Drives: E92 335i
03-31-2007, 03:59 PM | #4 |
15
Rep 367
If you could decipher the bussing signal off the PT-CAN going to the DME, and have something convert that to a signal that can be read to go into the Data logger, then maybe it'll work.
but odds are, you're probably out of luck..... |
04-02-2007, 01:13 AM | #5 |
24
Rep 824
Or you could just use the crank angle and cam angle signals just like how the 350Z guys do it (VQ35 has a CAN system also).
04-02-2007, 06:22 PM | #6 |
15
Rep 367
I dont think its a hall-effect signal coming off the crank (on-off). therefore i dont know if anything aftermarket would be able to read the signal.
Matt, can you back me up on this, or did they put a standard crank sensor in the E90? |
04-02-2007, 09:22 PM | #7 |
89
Rep 3,011
You could take the half-crank cam signal off the DME BUS signal and tap that into the dual-damper tacho-signal. Then just cross-wire the cam signal with the hall-effect crank (on-off).
Pretty straight forward. BTW: The e90 doesn't have a crank, much less a crank sensor....DUH!
"Teach the ignorant. Ignore the stupid."
04-03-2007, 12:00 AM | #8 |
319
Rep 2,748
Chesmu, your post makes my eyes hurt. WTF are you talking about?
Placey, I'm pretty sure the crank sensor on the E90 is just your standard hall, with the 60-2 crank teeth... I'd have to check. My E90 book is at work, and I won't be into work all week, though I am in Ontario all week for St-055. Matt |
04-03-2007, 12:17 AM | #9 |
89
Rep 3,011
04-09-2007, 11:05 AM | #10 |
Love my car!
Rep 78
Thanks guys... I think...
A couple of thoughts: 1. Is there a tach signal coming into (or out of) the DME? Seems like one of those pins would be RPM 2. Could I get an inductive signal - or even a direct tap - off of a fuel injector power line? Somewhere... somewhere there must be a "real" tach signal that goes into the computer to be CAN-bus-ized. I just have no clue where to find it. Thanks!
04-09-2007, 12:25 PM | #11 |
Love my car!
Rep 78
Found it!
I decided to scope my OBD-II connector with the hope that I'd stumble onto the RPM output, and sure enough, I hit a square wave on Pin #10!
I ran it to my data logger and bingo, a perfect readout. Here's a picture of the pin location, FYI:
04-09-2007, 02:15 PM | #12 | |
Deny everything
219
Rep 11,378
Drives: 2006 330i; 2015 X6, S1000RR
More pics and more details please.
I need a drink |
04-09-2007, 03:01 PM | #13 |
Love my car!
Rep 78
I'm going on vacation for the next week but when I get back I'll do the install of my G2Extreme data logger and post pix.
