Will These Fit?
05-28-2011, 06:01 PM | #1 |
Rep 70
Will These Fit?
I've found a set of wheels within budget as last set fell through.
Std wheels on car front 18x8 et 34 rear 18x8.5 et 37 New wheels..........front 18x8 et 20 rear 18x9 et 20 Is this offset going to be to aggresive and foul arches front and rear. I think they might as i realise this is an extra stick out of 14mm front and rear 17mm. Chers Davie |
05-29-2011, 05:14 PM | #2 |
10
Rep 87
Hi Dave, there is am offset calculator on this very site, go have a look - I reckon they will be sitting way too far out the wheel arch and could foul - find out what they have been fitted to. The E46 M3 for example has a completely different ofset to the standard E46 coupe even though the stud pattern is similar - stick with E90/91/92 alloys and you won't go far wrong - twist alloys and MV4's are a safe bett = I guess you have MV3's fitted at present
05-30-2011, 05:08 AM | #3 |
118
Rep 2,216
Drives: E91 330d M Sport
Yep, from the offset calculator on the wheels & tyres forum, the fronts will stick out an extra 14mm, the rears an extra 23mm - I'm not 100% certain what the E92 can take but that sounds way too much
Just how many Yorkshire sheep can you fit inside one exhaust?
05-30-2011, 06:53 AM | #4 |
Rep 70
Yeah have MV3'S at the mo, but provisionally sold to another member who will buy once I find my new set, had a set in mind in correct offset but fell through, have a chance of these but wrong offset, I was going to run with small spacers with the right offset wheels as there is a bit of room, but just wondered how much room have I and would these squeeze in obviously with no spacers.
