Removing E91 Rear Roundel?
05-24-2011, 11:01 PM | #1 |
118
Rep 2,216
Drives: E91 330d M Sport
I've searched here, other BMW forums, and over the internet, but I can't find an answer.
I don't want to go down the vinyl overlay route, because the edge of the roundel is starting to corrode, but none of the usual vendors seem to sell a proper replacement for the E91. I asked one of them - I don't remember which - and was told that it was too difficult to replace the rear roundel on an E91 which was why they offered the vinyl overlay instead. The tailgate diagram on RealOEM seems to suggest it's a similar setup to the front roundel, with holes behind the badge for lugs to sit in, but I can't find the right part number for the badge itself to check if that's actually the case... What I don't want to do is pull the old one off and not be able to replace it properly. Anyone with any suggestions? Thanks
Just how many Yorkshire sheep can you fit inside one exhaust?
05-25-2011, 02:08 AM | #2 |
192
Rep 6,110
Drives: Don't know yet!
If the roundel is fitted as per the bonnet, I did the following:
Fitted masking tape all around the roundel. Using an old credit card, I eased this under the roundel and with a small broad bladed screwdriver gently prised the roundel up. You'll need to move the card around the roundel prising up as you go. Heating the roundel with a hairdryer prior to doing all the above will help, as there is a spongy glued disc under the roundel that you can't see. Then this link will take you to the new roundel (scroll down) http://www.c3bmw.co.uk/StockItem.asp...&Item=unassign Or if you want to give us all a laugh, fit these http://www.c3bmw.co.uk/StockItem.asp...&Item=unassign
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience. |
05-25-2011, 02:25 AM | #3 | |
1545
Rep 8,970
E91 LCI badges: http://www.realoem.com/bmw/showparts...49&hg=51&fg=20 Item 1 only applies to 'hood' (bonnet) thus item 3 is for anywhere else (ie tailgate) grommets item 4. You'll need a soft plastic tool to prise off the old badge without marking the paint, or use metal tools wrapped in PVC tape etc, doesn't matter if it breaks off. It is a different part number to saloon and coupe tailgate badges, so maybe the low volume stops aftermarket badges being worth while to manufacture? Last edited by doughboy; 05-25-2011 at 02:47 AM.. |
05-25-2011, 04:08 PM | #4 |
118
Rep 2,216
Nice one Doughboy, thanks
If I can get a new OE roundel, I'm happy to put a vinyl overlay over that Edit: its 78mm if anyone is interested, and CF or monochrome roundels are available.
