Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > MPG display in BC stuck at 47MPG?
      05-16-2011, 02:54 PM   #1
NewRSoul
Drives: E90 2011
Hi all,
Not posted many times, but I have a query. My MPG as shown in the BC on the dash display is stuck at 47MPG no matter how hard or easy I drive?!?
Say I set off on a distance drive on the motorway after 20 miles or so the remaining miles of fuel display will start to rise, and after so 50 it's load (50-100 miles) more left then when I set off, so the MPG must be much better, BUT the MPG display doesn't change from 47!! Can I reset the BC somehow or is that a dealer only?
2011 320D 'ed' everything else seems OK, the gear shift advice numbers appear as normal too?
Any advice appreciated?
Peter
      05-16-2011, 03:21 PM   #2
MEGA
Dieseasal
MEGA's Avatar
204
Drives: LCI E92 335d M-Sport
It's very easy to reset on the older cars.
When mpg is displayed on the OBC just hold down the select button on the stalk and it will reset to 0.
Not sure if it's same on the LCI ed versions, but can't see why not..
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport
      05-16-2011, 03:54 PM   #3
HighlandPete
6659
Drives: BMW F11 535i Touring
Originally Posted by NewRSoul View Post
Hi all,
It is probably as simple as a really long term average. The OBC won't reset itself unless it reaches the maximum mileage within the programming. I'm not sure what BMW use, but VW have a 9,999 km cycle. So you can see why it doesn't change, if it is based on a large mileage figure. The rolling calculation of miles remaining is updated, using the last few miles average.
Another reason it doesn't move too readily, the BMW calcs are based on 0.1 litre/100km. So are a bit coarse in imperial measurement, and rounded out at that. Something like 46.3, 47.0, 47.9, 48.7, etc. VW run incremental calcs, even for the imperial setting, like 47.0, 47.1 47.2, 47.3, etc, so we do see a movement much more readily in a VW, even on long term averages.
So as MEGA says, you need to reset on the OBC stalk.
HighlandPete
      05-17-2011, 03:31 PM   #4
NewRSoul
Drives: E90 2011
Many thanks, I've reset the display and it's working again. I suggest that I'll need to do this each time I fill up!
