BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > new hifi alpine retrofit: gong and pdc sounds too low
      05-10-2011, 02:26 PM   #1
qwerti
Spain
Drives: e90 LCI
Although there's a post about the hifi alpine retrofit I'd like to get attention to this problem. My dealer told me there's no solution from BMW about this yet.
I've got a 2010 E90 LCI model with a professional radio headunit. After installing the new version of Hifi Alpine retrofit the PDC and gong sounds coming from the rear speakers are way too low compared to as they were before the retrofit.
The kit No is 65 41 2 163 268.
The previous version is not affected. Removing the retrofit is not an option as there's huge difference to the default speakers system.
Anyone is aware of this problem and has any news about this?
Any help will be appreciated.
      05-10-2011, 03:49 PM   #2
deeno
Drives: F30 330d Xdrive M SPORT
Have you tried increasing the volume for the gongs and pdc? what are they currently set to?
      05-10-2011, 04:19 PM   #3
qwerti
Spain
Drives: e90 LCI
oh, yes. The setup is set to +5 for each.
That's not the problem.
      05-10-2011, 04:56 PM   #4
Bungle009
10
Drives: E92 M3
I have an LCi 2009 car with alpine upgrade and dont have this issue.
      05-11-2011, 02:00 PM   #5
qwerti
Spain
Drives: e90 LCI
Do you know if the kit is the old or the new one? Did you install it?
Do you have the professional radio?
The new kit needs coding.
      05-11-2011, 02:57 PM   #6
script
script's Avatar
Drives: 335d E92
I upgraded but with a Vibe amp,gong was way too high until I adjusted the amp gains down,have you tried adjusting the amp?
      05-12-2011, 04:46 AM   #7
qwerti
Spain
Drives: e90 LCI
The kit is provided by BMW and it is installed by the dealer, so I don't think another amp is related to this.
To install this kit a coding of the car is needed according to the instructions I got. I think that the coding is not properly programed and turns down the volume for PDC and gong.
      05-22-2011, 04:28 PM   #8
kay-singh
Drives: M3
I have the same issue on my lci e93, but i used the pre-lci kit...
On Post lci cars, bmw suggests coding, maybe that is required to sort this?
Still not sure on the matter...
      05-23-2011, 02:47 PM   #9
kay-singh
Drives: M3
Hi mate, I resolved my issue, I wired my crossovers the wrong way around... sorted it now and its sweet!
      05-26-2011, 06:37 AM   #10
qwerti
Spain
Drives: e90 LCI
Good that you sorted it out
There shouldn't be problems with pre-lci kit. Maybe mine is also wrongly wired but the dealer did it, so I have to think they know what they do.
      05-26-2011, 11:47 AM   #11
kay-singh
Drives: M3
I would give it ago and checck if i was you... its really easy to do so, only four t20 screws and a few clips hold the door in!
      05-26-2011, 01:41 PM   #12
ibanezking
Weekend Rockstar
ibanezking's Avatar
England
39
Drives: E92 M3
maybe the apprentice did it................???
E92 M3 - Interlagos Blue and Black everything else!!!
