BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Headlight question
      05-05-2011, 11:41 PM   #1
bmw335inj
10
Drives: BMW 335i
Headlight question
Just got my new 2011 335i and when I got home and noticed that the headlights turned off as soon as I turned off the car. I checked the headlight switch it was set to automatic. Is there a way to keep the headlights on for 30 seconds or so? My Honda does it..
      05-06-2011, 12:39 AM   #2
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
481
Drives: 06 330i 6MT
after you turn the car off you can pull back on the turn signal stalk as if you were flashing your high beams. this will activate "pathway lighting" for a certain length of time that you can set in your car settings.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      05-06-2011, 01:52 AM   #3
ibarry92
44
Drives: 2010 BMW 328xi
If you have idrive go to settings and lights and you will be able to set the time the lights stay on. When you turn off the car...pull the high beam stalk towards you to activate them.
