07 e92 Coding Error
04-28-2011, 03:35 PM | #1 |
41
Rep 591
07 e92 Coding Error
So we ran into an error while coding an 07 e92 w/ cobb installed; did the digital speedometer stuff in the Kombi; and got a "speedometer malfunction" error; it's still there even after coding the module back w/ the blank man file; and even after un-marrying the cobb to the car; the error still is there; none of the gauges work now; ie tach/speed/fuel/temp/etc.. all the analog ones; anyone run into this error before?
IG: realantiks |
04-28-2011, 04:14 PM | #2 |
83
Rep 1,356
Well on this specific car, a birdie told me the only thing that works is the speedometer lol
So anyone got any ideas...help a brotha out. The gauges all kick in for a good 30 seconds and than the tach / temp / gas gauges all fall and iDrive says "speedometer display malfunction" |
04-28-2011, 04:27 PM | #3 | ||
83
Rep 1,356
Hey Antiks
I was reading on another forum and people have encountered the same error, they did the following Quote:
04-28-2011, 04:45 PM | #4 | |
83
Rep 1,356
it also says
04-28-2011, 06:00 PM | #6 |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
Update? Hope it worked out for you. New daten and a blank flash should do ya.
04-28-2011, 07:25 PM | #7 |
41
Rep 591
yup that worked; however the new daten files won't read the nfrm anymore..lol..strange i know..but we coded all that w the old daten files
IG: realantiks |
04-30-2011, 02:20 PM | #9 |
SYTFU Crew
36
Rep 1,179
I've actually tried to update daten and got a Faulty Chassis error and reverted back to my previous files.
Did you run into that error and fix it?
05-03-2011, 11:32 PM | #11 |
Rep 3
Same Problem
Antiks,
I am facing the same problem with my analog gauges after coding the Kombi Module. Now after updating daten files with either ista v34 or v40 I always get the "chassis faulty" error in ncsexpert. Could you share with us which version daten files that you used and the process followed for updating them without errors? Thanks. My Current Setup: 1. 2006 e90 (330i) - Had programming done at the dealership in mid April '11 2. Ediabas version: 6.4.7 2. NCSexpert version: 3.1.0 |
05-04-2011, 09:43 PM | #12 |
Rep 3
Update:
Solved my issue using ISTA v41 Daten Files. 1. Copied and pasted new daten files to [ C:\NCSEXPER\DATEN\E89 ] and ran laden.bat 2. Copied and pasted new sgdat files to [ C:\NCSEXPER\SGDAT ] 3. Copied and pasted new ecu files to [ C:\EDIABAS\Ecu ] This time NCSexpert worked fine, no "Faulty Chassis" message! Re-coded with a blank .MAN file and functionality my the analog gauges (rpm/mpg/fuel) were restored! Last edited by jyono; 05-04-2011 at 09:50 PM.. |
05-05-2011, 06:20 PM | #13 | |
41
Rep 591
IG: realantiks |
05-06-2011, 02:53 PM | #15 |
SYTFU Crew
36
Rep 1,179
great news! i'm updating to v41 today and seeing if my faulty chassis message goes away.
06-27-2011, 08:11 PM | #18 | |
247
Rep 966
Drives: F30 335i M sport
09-03-2011, 09:42 PM | #19 | |
133
Rep 2,517
Drives: '11 335xi e92 M-Pak
09-06-2011, 07:52 PM | #21 |
133
Rep 2,517
09-06-2011, 08:53 PM | #22 |
41
Rep 591
IG: realantiks |
