2010 2011 BMW 5 Series Forum F10 Whiteline tail lights installation |
11-27-2011, 09:39 AM | #3 |
716
Rep 2,003
Remove the pins holding the trunk trim, middle and sides, only the part allowing you to reach inside to get to the lights. Its quite a logical progression, not hard at all for beginner.
But you need a 8mm long drive socket, for the middle lights. The others are reachable with normal adjustable wrench. Unplug and replug. Quite simple, just need the 8mm long drive or you'll be stuck. |
05-31-2012, 10:04 PM | #4 | |
81
Rep 1,391
Drives: F10 G29
06-01-2012, 12:26 PM | #5 |
38
Rep 158
I Just Change Mine Yesterday And It Was Very Easy. They Are Not Screws , Look Like Them But They Are Plastic Ones That Snap In And Split Inside So First You Need To Do Is Get A Pliers And Pull The Screw Out And Then pull it all together.
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS RACECHIP XLR Last edited by GIANITALY; 06-01-2012 at 12:44 PM.. |
07-12-2014, 09:38 AM | #6 |
Rep 4
I found this in case someone is looking
I found this in case someone is looking to replace tail lights Here u go:
BMW_F10_White_Line_TailLights.pdf> |
