04-19-2011, 03:28 PM | #1 |
Moderating
418
Rep 2,047
Akrapovic Sound with SS catless DP's
Nate you champion!!
The box finally arrived!!! I am not going to waffle on about how amazing the system looks and the quality blah blah IND are champs, Nate is a champ etc etc everyone whining like girls about not loud enough, not cool enough, not aggressive enough Check this out: AT IDLE CRUISING IN DRIVE CRUISING IN M DYNAMIC SPORT MODE Last edited by Bob MG; 04-20-2011 at 11:40 AM.. |
04-19-2011, 04:47 PM | #2 |
23
Rep 53
That sounds amazing! Very similar to many turbocharged V8 race cars.
Its funny to keep reading about people complaining how quite/weak sounding the X///M engine is with the stock exhaust... Little do they realize cause is the factory catalyst. Once removed the true sound of the V8 TT w/ 600+hp comes to life. I can't wait to put my downpipes on in a few weeks. |
04-19-2011, 09:27 PM | #5 |
44
Rep 567
I was waiting for this.....OMFG
Sounds sick, almost viper like....F-1 like.,,, How about a little clip from the exterior pretty please I think I'm fully doing this mod....
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
04-20-2011, 12:38 AM | #7 | |
Moderating
418
Rep 2,047
I will see what I can do, maybe get my wife to video me cerraring down the road like a toss to record my exhausts sound NOT!! all jokes aside I will do some regular driving speeds so you can hear idle and low revs It's actually sounds quieter at low rpm with the akra fitted than before with SS DPs and the OEM bitch can. The sound was very farty like since the engine was breathing more air down the OEM rear section and it sounded a little wierd to say the least. Now at idle and low rpm, it's sounds like there are 670 Horses biting each others asses to kick out. On pull away it settles the irritaiing flapping sound I got before (a bit like putting some cardboard in your wheel spokes as a kid to pretend you were on a Harley) and now it's sounds like a proper V8 TT On flat out it sounds a little raspy and high pitched like a Ferris CS stradale. (I had one, so sorry of analogy is a bad one) Stay tuned, shoot me a pm if anyone needs any assistance on this as the whole project was a first since there were no real write up on the SS DPs before I bought mine, plus the ESS 100 RON tune and finally the 5 month wait for the Akra. |
04-20-2011, 12:46 AM | #8 |
Rep 39
woowwwww wooowwwww wooowwwwww!!!! that sounds like a Maserati GT with a sport line exhaust. should i just put sport cats to get this sound? what sport cats did u get?
2010 BMW X6 heavy, but yu///Mmy
2002 BMW e46 ///Mic jerky 3 - Sold 1995 BMW e36 ///Mic chassis flex 3 - Sold |
04-20-2011, 10:26 AM | #10 | ||
44
Rep 567
I can't see where the jump in hp occurs Tune~ 50-60 for 100 RON exhaust ~ 10-12 Dp's your thinking ~ 50-60? Would love to see your beast dyno'd Not trying to be negative, just would like to see hard numbers
04-20-2011, 10:33 AM | #11 |
Moderating
418
Rep 2,047
This is ESS dyno of 95 RON tune and SS Cat-less DPs
I have the 100 RON tune plus the Akrapovic Evolution Hammann makes 670 HP what they got that I don't? Maybe AJ can chime in here? Last edited by Bob MG; 04-20-2011 at 10:38 AM.. |
04-20-2011, 12:14 PM | #13 | |
44
Rep 567
I had read that on some board somewhere
04-20-2011, 12:53 PM | #14 |
Moderating
418
Rep 2,047
04-20-2011, 11:56 PM | #15 |
Rep 39
aaaahhhhhhhhh i just finished!!!!
04-24-2011, 10:22 AM | #16 |
Moderating
418
Rep 2,047
This is off Hammann website:
http://www.hamann-motorsport.com/en/...engine-tuning/ HAMANN* SPORTKIT HM 670 * Power increase up to 670 hp / 493 kW Max. Torque 950 Nm at 1.500 - 5.650 rpm V/max 300 km/h Consisting of: HAMANN Catalyst replacement pipes** Item-No.: 50 071 550 HAMANN Sport rear muffler with 4 tailpipes HAMANN Optimized curve maps specially for * * * * * * * Sportkit HM 670 HAMANN Deactivation of standard 250 km/h speed limit Tires have to cope with higher maximum speed ! ! Export only ! The technical data given refers to the German version. Due to certain legal regulations in different countries, deviations in the technical data described here can accur. Results may vary depending on basis engine, vehicle equipment, transmission, gear and final drive ratios, wheel/tire combination, etc. To reach the maximum power of petrol engines, you need to use top graded fuel Super Plus 98 ROZ. * It is explicitly stated that the * marked parts are ** race sport parts without german TÜV approval ! |
04-26-2011, 03:01 AM | #17 |
Rep 27
regardless of 670hp or not, man.... this is nuts, sounding awesome and amazing, a true beast to be heard and shown
well done, Bob, thanks for sharing, now i am thinking to remove my Eisenmann for Ak |
04-27-2011, 04:31 AM | #19 | |
Moderating
418
Rep 2,047
Check out the differences on the dyno above. First one is with stock cats and 95 RON fuel tune Second one is for catless 95 RON tune (NOTICE HOW THE CAT-LESS HEADERS ALLOW THE POWER TO GAIN AS MUCH ON THE TOP AS THE MID RANGE FROM STOCK, WHILE THE TUNE WITH OEM HEADERS LOSES THE POWER GAIN RATIO ON HIGHER RPM RANGE) I haven't dynoed but mine has the Akrapovic rear section which is good for another 10 hp and 15 torque, plus I have tune for 100 RON which I'm sure is good for anther 10 -15 hp also and a shit house full of torque ESS has tunes for both options as well as different fuel used I have 2 tunes from ESS: 1. catless 95 RON 2. catless 100 RON fuel |
04-27-2011, 08:56 PM | #20 | |
461
Rep 935
05-05-2011, 06:02 AM | #22 |
Rep 31
So they use the turbo upgrade to get to 670hp, would explain why the kit is so bloody expensive. But on that note i would have thought that their kit would have made more, isn't your car making close to or 670hp without the turbo upgrade.
The car is 408kw stock and only 493kw with the Hamman kit, so thats a 85kw gain for $16,000 |
