Error trying to code module KOMBI (IFH-0003: Datatransmission to interface disturbed)
04-13-2011, 09:09 PM | #1 |
pullin a boat
37
Rep 479
Hello,
I have a 2009 328i xDrive and have been trying to code BC_DIGITAL_V and some other features in module KOMBI. I can read the KOMBI module without issue, but anytime I try to do "Basic Functions->coapiReadSgGetFswPsw" it gives me the following error after the dialog box: COAPI-2000: EDIABAS or SGBD error IFH-0003: DATATRANSMISSION TO INTERFACE DISTURBED Any ideas? This is my first time coding this car.
2021 X3 M40i, Phytonic/Cognac Past: 2017 330i xDrive Touring M Sport, EBII, Dinan 2014 328d xDrive Touring M Sport, BSM/CR. |
04-15-2011, 12:58 PM | #2 |
43
Rep 161
Drives: 2017 BMW M3
similiar issue
I get this when walking through the DIY and attempting to read from the airbag module:
From the INPA FAQ (the code and message do not line up, but the doc is attached - page 4,5): 1.4 IFH-0003: Data transmission HOST/Interface failed
1.5 IFH-0010: Data transmission to control unit disturbed
Of course with Windows 7 (vista, etc) will need the serial registry values updated to match these. I was about to post my own topic on my issue (reading and getting the same error). I haven't been able to figure it out, hope this helps. EDIT:: After that post, I found the resolution to my issue, drivers. I uninstalled the devices and drivers under the windows device manager and rather than installing the drivers which came with the software (cause of the my problem). I configured windows to search windows update for appropriate drivers and now everything works. Good luck.
2017 BMW M3 - Tanzanite Blue with Full Silverstone Interior
04-17-2011, 10:24 AM | #4 |
pullin a boat
37
Rep 479
Well, I have a USB cable so those FIFO parameters are non-existent. I've determined that I can read/code the car but I need to try it 15-20 times before it goes. I think I might have a COM port conflict
04-17-2011, 10:55 AM | #5 |
252
Rep 7,089
Drives: '06 AW 330xi
Try keeping your hazards on
It prevents the module from going to sleep. Last edited by fdriller9; 04-17-2011 at 11:18 AM.. |
04-17-2011, 12:04 PM | #6 | |
43
Rep 161
Drives: 2017 BMW M3
HEKY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\servic es\Serial RxFIFO TxFIFO Both should be a DWORD, 32-bit, hexadecimal, and set to 8: 0x00000008
05-27-2011, 09:58 AM | #8 |
31
Rep 402
Not sure if this will work for you, but I got that error when I was running just off the battery. Hooked up a battery tender and all was good. So, maybe that will work for you? If not, I don't know what else to try.
05-28-2011, 12:15 AM | #9 |
15
Rep 324
didn't work. what message do you get when you run ncs with the cable plugged into the computer only?
05-28-2011, 10:20 AM | #10 |
31
Rep 402
I get the same message you get with cable plugged into computer, using fsw psw profile, do the f1, f3 thing, then get the exact error message comes up that you have. So, it's not reading your car somehow.
05-28-2011, 01:27 PM | #12 |
15
Rep 324
05-29-2011, 01:03 PM | #13 |
14
Rep 96
Drives: E90
If your latency settings are set to 1 then maybe you can try this...
Make sure that after you read the KOMBI that you go to the "work" folder and open the FSW_PSW (TRC File). Then, as DIY say's click File > "save as" FSW_PSW.MAN and set to read "all files" instead of "text". Then open your FSW_PSW (MAN file) and make your changes to the KOMBI. Then try doing the "Basic Functions > coapiReadSgGetFswPsw" and see what happens. Sometimes when I go too quickly and forget this step, I get the same error message you get.
05-29-2011, 01:17 PM | #14 | |
300
Rep 4,444
05-29-2011, 03:17 PM | #15 |
14
Rep 96
Drives: E90
Haha Grant, I know what you mean! Sometimes I open the .trc file and make my coding changes there! Although, I usually catch my mistake before I go to save it as a .man file.
05-30-2011, 11:47 PM | #17 |
14
Rep 96
Drives: E90
Hey E90al,
A few things you can try: 1.) Plug cable into car, turn ignition on, and run INPA. Make sure both dots are black. If you do not have both black dots then close INPA and try running program again. If you do have both dots black, close INPA (but leave Ediabas server on). Don't proceed with the next step until functionality between your computer, cable, and car are established. 2.) Make sure you are running NCSEXPERTool as an administrator on Windows. To do this you can right click on the NCSEXPER icon on desktop and click "run as administrator". 3.) Update your daten files. You can do this a couple of ways, the easiest is to go to NCSEXPER folder (should be located in c > Daten > E89 > Double click and run "LADEN" file, this should update yor daten files automatically. Another way to do this is to copy and paste new daten files that you can get off the internet. Tr searching for them, or I can help point you in the right direction. 3.) Make sure you are using the correct drivers for your OBD ebay cable. The drivers for the ebay cable are located here (http://www.ftdichip.com/Drivers/D2XX.htm)
06-02-2011, 06:53 PM | #18 | |
15
Rep 324
3. When you update where do you put the downloaded files? 4. When I use the drivers from the website, I get a BSOD that has something to do with ftdi.sys(something like that). The only way to avoid bsod is using the drivers in the Ediabas\hardware\obd\winxp\usb2.0 folder. If it is a faulty cable, i would like to return it asap because warranty for it is almost over. |
06-10-2011, 02:31 PM | #19 |
64
Rep 407
Hi,
I'm getting the same error with a 2008 E92 M3. Does anybody know what might be causing this? I know for sure that it's not the cable since it works perfectly with my 2006 E92 335i.
06-10-2011, 03:59 PM | #20 |
252
Rep 7,089
