04-11-2011, 09:49 PM | #2 | |
4 Star General -Twilight Zone
36
Rep 1,032
04-11-2011, 10:27 PM | #3 | |
890
Rep 7,047
It's not a smaller M3. |
04-12-2011, 05:44 AM | #4 | |
36
Rep 1,032
Look at 1:20 into this video Last edited by DiavelM3; 04-12-2011 at 05:50 AM.. |
04-12-2011, 06:05 AM | #5 | |
125
Rep 1,297
04-12-2011, 09:16 AM | #6 | |
La Flama Blanca
27
Rep 1,545
And the pieces will fit on the 135. All the parts are available at HP Autowerks. |
04-12-2011, 09:51 AM | #7 |
699
Rep 2,548
Drives: '08 135i, '88 325is
That reminds me of what someone once called my 135. They described it as a "335 SWB" (short wheelbase) model.
Delivered in Munich, broken in on the Nurburgring.
04-13-2011, 04:26 PM | #8 |
51
Rep 589
Drives: BMW 1M
Somewhat related. I saw on the 2012 135i performance suspension. I wonder if it is the same as the 1M.
04-13-2011, 04:31 PM | #9 |
La Flama Blanca
27
Rep 1,545
04-13-2011, 04:51 PM | #10 |
53
Rep 659
The don't sell the springs and dampers. I have the front control arm kit and I know I will need the rear kit but what about those springs and dampers?? Will they fit?
04-13-2011, 05:14 PM | #11 |
13
Rep 220
The M1 chassis may be a shortened M3 but are you saying that the 128/135 chassis are different than the M1? That's hard to believe. Set up differently, sure, but stamped from the same press.
2012 Alpine White 135i | DCT | Dinan Stage 3 | ER Charge Pipe | P3 Cars Boost Gauge | Performance Suspension | Terracotta Leather | M Sport Pkg | Premium Pkg | Heated Seats | Comfort Access |
04-13-2011, 05:21 PM | #12 |
La Flama Blanca
27
Rep 1,545
If the 1M has an M3 chassis, how can it not be different from the 128/135? They don't have an M3 chassis.
04-13-2011, 05:22 PM | #13 |
La Flama Blanca
27
Rep 1,545
04-13-2011, 05:26 PM | #14 | |
112
Rep 1,140
Quoted from BMW m-power.com site. http://www.bmwblog.com/2011/02/20/pa...at-high-speed/ |
04-13-2011, 10:38 PM | #15 |
Rep 187
How can people STILL not get this?? It's been discussed for months. The 1M is almost totally different to the 135 under the skin. It has different dimensions in all directions for heaven's sake!!
Happy in the Jaffa...
04-14-2011, 12:11 AM | #16 |
674
Rep 4,080
Quite a bit of work has been done over on E90 post working out the M3 suspensions. Depending on your $$ threshold you can convert most all of the 135/335 suspension over to the M suspension. That said the M3 Dampeners/Springs are not the end all be all. Plenty of options out there which could outperform stock m bits. Just visit the M forum and read for yourself.
The real question should be why? For the E9X it's about the difference between normally aspirated and forced induction. With the 1m it seems a no brainier. You want m performance then get a 1m, it will be cheaper. |
04-14-2011, 02:22 AM | #17 | |
191
Rep 4,848
The 1M has the front and rear subframe of the M3. Which is much more than just the spring and dampers. However, since the M3 bits was able to dial out a lot of unwanted understeer the 135i has, I would assume 1M bits would do the same too.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
04-14-2011, 09:43 PM | #18 | |
890
Rep 7,047
I was under the impression that the 1M was a 1 series chassis with M3 sub frames, suspension and steering components. The video says, "essentially", so for the most part the 1M seems to have much in common with the M3. But, I wonder what "essentially" means? IOW, what are the differences? I haven't read as much on the 1M as some of you, but I clearly missed that. Can you point me to an actual technical review of this information? Much appreciated. Last edited by RPM90; 04-14-2011 at 10:27 PM.. |
04-15-2011, 12:19 AM | #19 |
39
Rep 812
Re "essentially" - it's shorter, so it's obviously not *exactly* the same
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
04-15-2011, 12:38 AM | #20 | |
890
Rep 7,047
I read a good bit about the M3 bits put on the 1M, but not so clear that the 1M is simply the whole M3 chassis just shrunk a bit. That could be, but do you have something I can read that states and supports that it's the whole M3 chassis only shorter? If it's only shorter, then it could easily be said that it's exactly the same "only shorter". I don't see a shortened chassis being termed "essentially". |
04-15-2011, 12:48 AM | #21 |
16
Rep 242
If you put all of the M3 suspension bits that are in the 1M on a 135 it means you'll have to widen the wheel arches as well, then you have to change the flywheel, get a different steering rack, not to forget a LSD and maybe some new seats, chances are when you're done it would have been cheaper to buy a 1M in the first place.
I'm sure with the right careful selection of mods upgrading the drivetrain and the suspension of a 135 you could end up with something close enough to a 1M, and if you already have a 135 maybe that's cheaper to do than selling it and trying to get a 1M but you probably would have to be very good at picking those after-market parts and end up with a package as good or as well matched as what the M engineers ended up with in the 1M, they after all had the luxury of being able to try any existing part in the M catalog bolting it on go for a day lapping the ring, record the lap times and then trying the next part, etc... until they got to the 'right combination'. |
04-15-2011, 01:48 AM | #22 |
39
Rep 812
That would however be nonsense in English. Either it is exactly the same or it isn't. As we know it isn't, the word exactly cannot be used. It's like saying something is "fairly unique".
