04-07-2011, 04:17 PM | #1 |
Supreme Allied Commander
3841
Rep 54,349
Drives: F80 M3
>> HP Autosport << Stoptech Big Brake Kit - EXCLUSIVE Pricing for M3 Post Members
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track. Advantages of StopTech over other brake upgrades: -Shorter Stopping Distances -Better Brake Modulation -Firmer Brake Pedal -Less Brake Fade Feature Benefit Summary: -Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel -Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life -The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper -Track testing of new applications ensures optimum performance For those looking to put their car on a diet: 4 lbs on the front rotors. 2 lbs on the front caliper and bracket. 3 lbs are on the rear rotor 1 lbs on the rear caliper. The key here isn't about the weight savings but the increase in the amount of heat capacity available. Application and Pricing Front 15 inch BBK ST-60 6 Piston Calipers Floating 380x32mm AeroRotors MSRP - $3695.00 Front 14 inch BBK ST-40 4 Piston Calipers Floating 355x35mm AeroRotors MSRP - $2995.00 Rear 14 inch BBK ST-40 4 Piston Calipers Floating 355x32mm AeroRotors MSRP - $2895.00 Additional Price Info Red / Black / Silver Calipers - No Additional Cost Blue / Yellow / Gold - $200.00 per axle Slotted Rotors – No Additional Cost Drilled Rotors - $100.00 per axle -For gold, blue, silver or yellow calipers, please add 4 weeks for lead time. Please shoot us a PM for your M3Post Member price! Last edited by HP Autosport; 10-01-2014 at 05:18 PM.. |
07-23-2011, 09:13 PM | #3 |
NSDQ
32
Rep 340
Drives: E92 M3
please pm pricing for:
Rear 14 inch BBK ST-40 4 Piston Calipers Floating 355x32mm AeroRotors Thanks!
09-05-2011, 05:30 PM | #4 |
3841
Rep 54,349
Drives: F80 M3
09-05-2011, 05:42 PM | #5 |
chris
278
Rep 12,144
pm me pricing for replacement pads for my 380mm/355mm stoptech bbk. need it shipped to upstate NY 12919.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
09-11-2011, 12:51 PM | #6 |
3841
Rep 54,349
Drives: F80 M3
10-13-2011, 12:17 PM | #7 |
35
Rep 113
Stoptech BBK
Please PM price for 380/355 setup for my 2009 e90 m3. Black calipers with slotted rotors and street performance pads. Car is dual purpose daily driver / HPDE car. Thanks
02-16-2012, 01:48 PM | #8 |
18
Rep 271
PM me price shipped to 91007 for fronts only 6 piston thanks! 16 inch
04-18-2012, 12:34 AM | #9 |
3841
Rep 54,349
Drives: F80 M3
05-01-2012, 08:11 AM | #10 |
Rep 148
PM for Trophy 380mm, slotted, front only shipped to Portugal. Thanks
05-01-2012, 05:51 PM | #11 |
3841
Rep 54,349
Drives: F80 M3
11-15-2012, 08:14 PM | #13 |
3841
Rep 54,349
Drives: F80 M3
07-03-2013, 12:37 PM | #15 |
3841
Rep 54,349
Drives: F80 M3
Retail price increase of $300 per axle affective 7/1.
Your discount % does not change with us so PM us for best prices! |
10-01-2014, 02:45 PM | #18 |
DSC Off!
304
Rep 718
Please PM best price for ST-60 slotted front to 75218.
Thanks, Harold.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
01-27-2015, 09:07 PM | #20 |
57
Rep 600
Drives: 2012 E92 SSII ZCP DCT
pm price for ST60F/ST40R with slotted in Red and Blue thanks
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER |
