Problem with MS-8 "Voltage too high"
04-07-2011, 11:05 AM | #1 |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
i was adding an amp for my rear speakers yesterday
and cleaning up my wiring etc after i was done the MS-8 keeps turning off with "Voltage is too high" on the screen. only happens with the engine on, if the engine is off it works fine i measured the voltage, it's 14.5-14.6v with the engine running. i believe the norm is 14.4 any ideas? i read the manual, it says of you get that message there might be something wrong with the car. what's the average voltage you guys are getting? and is the voltage adjustable from the alternator? |
04-07-2011, 11:20 AM | #2 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
04-07-2011, 11:32 AM | #3 |
688
Rep 6,845
the only thing different now, vs the last 6 months, when i first installed the ms-8 is, the rear speakers are no longer being powered by the ms-8
i got a small amp for them, since my other amp is powering the front, center, and subs. the delay is only adjustable for turn off, not turn on just checked the manual weird that it was working fine till i organized my wires |
04-07-2011, 01:03 PM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
Mine is between 14.4 and 14.8.....usually chills around 14.5 though.
04-07-2011, 02:40 PM | #5 |
688
Rep 6,845
i redid the calibration
i thought maybe the fact that it was powering the rear speakers in the first calibration and now it's not might make a difference after doing it it works! fingers crossed that was the real reason behind the error message |
04-08-2011, 11:27 AM | #6 |
688
Rep 6,845
nope, same thing again today
called JBL they suggested using thinner gauge wire, especially since i am not using the built in amps, so don't need such thick wire. so if the max it can pull is 16A (from manual) i can use 16 gauge wire the reason is thinner wire has more resistance than thicker wire (i was using 8 gauge) if i use 6 feet of 16 gauge wire, i should get a 0.2v drop so it should be at 14.4v weird solution but will try it |
04-09-2011, 04:26 PM | #7 |
688
Rep 6,845
Finally figured this out
Had to use a resistor on the power line to bring the voltage down Used 2 1ohm 10w resistors in parallel Voltage is now 13.8 For future reference, the MS-8 draws 1amp when you're not using the internal amps |
