03-28-2011, 06:39 PM | #2 | |
2868
Rep 11,374
2" / 1" - With Self-leveling 1.2" / 1" - With Self-leveling
03-29-2011, 02:57 PM | #3 |
Rep 16
Thanks Nate. I did purchase the 1.2" / 1" - With Self-leveling and after installed my driver side sat 1" low. I adjusted the link arms to compensate and it now sits level. Should the link arms be different lengths? The factory link arm lengths are both the same.
Eric |
03-29-2011, 05:32 PM | #4 |
2868
Rep 11,374
That could be caused by a bent sensor bracket. The level sensor box itself is mounted to the suspension arm with a bracket, and if the sensor box moves on it's mounting point your car could see an inaccurate reading and therefore change the height on that corner.
I'd suggest looking at the mounting position of the sensor box on the left side vs the right, and make sure they are positioned evenly. That's a good first step.
03-29-2011, 08:43 PM | #5 |
Rep 16
I spent hours under that car to see if the bracket was moved or bent by the installer but I can't seem to see anything. For some reason the installer did take the sensor off so I also looked to see if it's put back wrong but that's hard to screw up with the registers. Could swapping sides do it? If he by some chance put right on left?
Thanks for the help!!!! |
