Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Some specific coding questions
      03-26-2011, 02:35 PM   #1
woodpecka
woodpecka's Avatar
68
Drives: E91
I have successfully coded a few features on my e91 2006.
I have a few issues to get access to some value, I don't understand why they are not available in the modules TRC files but present on the car TRC file.
JBBF (2JBBF) ZYCLUS_VOLLEND_KLR_AUS Wiper wipes to End position after turning engine off (not present in my KOMBI TRC file but present in my 221k car TRC file)
KOMBI DIGITAL_KVA Instant MPG (not present in my KOMBI TRC file but present in my 221k car TRC file)
I also don't found the LMA module. Is it supposed to be available on a pre lci?
      03-27-2011, 08:36 AM   #2
woodpecka
woodpecka's Avatar
68
Drives: E91
Anybody knows?
      03-27-2011, 09:14 AM   #3
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
This is in the JBBF or 2JBBF module (not Kombi).
Try BC_DIGITAL_V in the Kombi module to get the digital speed display.
ER_KEYOUT_AUTOVR
Are your setting set so that the car auto lock the doors when you drive off? This should be on
LMA is a module not used on the e9x cars. I believe it is similar to our FRM or NFRM module
      03-27-2011, 10:58 PM   #4
woodpecka
woodpecka's Avatar
68
Drives: E91
I have coded a few parameters with success in the KOMBI, including the V display.
I can't found ZYCLUS_VOLLEND_KLR_AUS in the JBBF (!?)
ER_KEYOUT_AUTOVR is working now!
      04-04-2011, 05:18 PM   #5
dcan
Austria
Drives: PL2
Enabling BC_DIGITAL_V in itself is not enough, if you want to see the real measured speed - in this case, you have to disable BC_DIGITAL_V_KORREKTUR, too. Since speedometers aren't allowed to show a lower speed than the actual speed, and an exact speed measurement is not always possible, all manufacturers correct the measured speed slightly upwards in order to comply with ECE-R 39 regulations:
http://www.unece.org/trans/main/wp29...gs/r039r1e.pdf
Look for the formulae under Annex 3, Section 2. The U.S. regulations must have a similar counterpart, too.
      04-04-2011, 05:49 PM   #6
woodpecka
woodpecka's Avatar
68
Drives: E91
I have disable BC_DIGITAL_V_KORREKTUR with success!
I tried to disable BC_V_KORREKTUR thinking that I would get the real analog speed but this one has no effect.
      04-05-2011, 03:07 AM   #7
dcan
Austria
Drives: PL2
That's a different pair of shoes; it configures whether corrected speed values should be used for BC calculations. So, it has an effect, too.
      04-06-2011, 11:52 AM   #8
dcan
Austria
Drives: PL2
That's because you don't have a JunctionBox II, but a JunctionBox I, with an old SW below CI-7.
      02-06-2012, 01:39 PM   #9
vadim77
Drives: 318i
what is the 221k file? I can't activate digital-kva function!!! In Kombi ok (active), but no info in cluster)
      09-13-2012, 11:48 AM   #10
toicy4ya
toicy4ya's Avatar
47
Drives: 06 BMW 330XI
How did you get it to work? Did you do in CAS?
Did you also have to mod Komfort_Eject along with it?
2006 330XI BSM, Terra Cotta Leather Interior, ZSP, ZPP, ZWP, ZCV, Comfort Access, Adaptive Xenon, Steptronic, Logic 7, Nav w/ IDrive
      09-16-2012, 09:35 PM   #11
Elliott@DetailAddict
300
Drives: E90
In order for the Unlock on Keyout to work, make sure the car is set to lock itself upon driving.
That has to happen for the unlock to work.
      09-16-2012, 11:19 PM   #12
rentonrider
32
Drives: E92 M3
2011 BMW M3  [7.00]
