Alarm Coding Changes
03-22-2011, 12:41 PM | #1 |
20
Rep 146
Hi,
I have already installed the physical alarm on my car, and got the clown nose blinking. I know I have yet to code the alarm to fully integrate it, but I had a few questions regarding the coding. I know there are options that you are able to access after coding, and certain differences. However, I was wondering if anyone had a comprehensive list on the changes after coding versus just leaving it installed without coding. From what i have been reading, this is what i've noticed: -Panic enable -IDrive menu chirp enable on lock After installing the alarm my clown nose has already been activated. Also, is it even necessary to code to have the alarm "function"? The reason i ask is, there have already been several occasions where my car's alarm was set off. My friend walked by my car when the windows were down, and the alarm went off. Also, it went of previously in a garage due to a loud exhaust (yes, it was a meet ) Sorry if this has been covered in other threads, but i haven't found anything comprehensive regarding this topic quite yet. |
03-22-2011, 01:33 PM | #2 |
547
Rep 6,563
did you see this post...that is pretty comprehensive down to the different values you can compare with what you have. It would be interesting to see what values you have before you make any changes.
Sound like your alarm is configure at a very sensitive level but I did not see any configuration for sensitivity in coding the alarm. http://www.e90post.com/forums/showthread.php?t=504338
under construction! |
03-22-2011, 03:30 PM | #3 |
20
Rep 146
Thx!
Yeah i saw that thread with the values. My main confusion is regarding the functionality of the alarm. It seems the alarm "works" without coding in the event someone tries to steal or move my car. However, coding is required for access to options and settings. Correct me if i'm wrong? |
03-22-2011, 03:50 PM | #4 | |
555
Rep 1,244
Drives: 2013 F10 M5
03-22-2011, 05:00 PM | #5 |
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
You are missing out on other features.
The tilt feature isn't activated, the beep when you lock the cars isn't activated and the hood switch isn't activated. Coding the car will get you these other features that come with the alarm. |
03-23-2011, 02:41 AM | #7 |
1429
Rep 3,881
I don't believe the alarm volume can be adjusted through the idrive or the control stalk. This can only be done with a programmer attached to the vehicle.
03-26-2011, 07:20 PM | #8 |
No 55mph
1616
Rep 8,474
It most definitely cannot be adjusted by using the stalk (iDrive IDK). You can/have to change the alarm chirp volume thru coding in the DWAS module under BUZZER_HIGH_LEVEL
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-20-2012, 04:25 PM | #9 |
66
Rep 850
I just installed my alarm and did the coding. It was really quiet so I went in and changed to wert_08 still really quiet. So i ended up coding with a blank MAN file and now its really loud. Worked great!
07-02-2013, 06:33 AM | #10 |
Rep 55
Sorry to resurrect this thread, but when you say it was a blank MAN file, which part was blank?
If it was all blank then the alarm would not function at all surely. Do you mean the specific coding parameter for BUZZER_HIGH_LEVEL? |
07-02-2013, 07:04 AM | #11 |
37
Rep 252
He means recode your module. You don't have to use blank (empty) FSW_PSW.man to do this, you can use EXPERTMODUS profile, select ECU and EXECUTE JOB with SG_CODIEREN.
07-02-2013, 07:12 AM | #12 |
Rep 55
I can code it via NETTODAT if I know what the HEX is. If the OP can read his file and tell me what the HEX is i'll do it that way. Its the only other way I know.
I assume if its blank it will be either 00 or FF at the HEX address? |
07-03-2013, 03:44 AM | #13 |
Rep 55
I'm fairly new to this still and i'm not sure what this actually means. /
07-03-2013, 11:35 AM | #14 | |
295
Rep 2,201
Does this essentially resets the module to factory or just performs a restart of the specific module only?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-03-2013, 11:51 AM | #15 | ||
Guest
Rep n/a
Drives:
07-03-2013, 03:35 PM | #17 |
37
Rep 252
01-14-2016, 07:08 PM | #18 |
Touring cars rock
350
Rep 904
Going to resurrect this thread once more as I am trying to code my alarm on my 2007 e91 Sportwagon.
I have had no issues writing the VO code using FA_WRITE to CAS, however when selecting the ECU to do an FA_WRITE to LMA I do not see LMA as an option in the selection menu. I'm wondering if on the e91's in '07 if it needs to be written elsewhere? Thanks in advance. |
