RFT Replacement
03-22-2011, 05:13 AM | #1 |
Detailing
13
Rep 440
RFT Replacement
The rears on my car will be due for replacement in a few thousand miles time - and I'm probably going to change to non RFT -
What I need to know is, as my fronts still have plenty of life left in them can I run a split set up ie RFT's on the front and non RFT's on the rear? I don't really want to bin the fronts ideally! |
03-22-2011, 05:26 AM | #2 |
21
Rep 482
no, you can not mix rft with non rft, car will be dangerous to drive! take the fronts off and flog them on ebay, you can use the money and put it towards paying for the non rft's
03-22-2011, 05:39 AM | #3 |
1867
Rep 13,043
Drives: BMW M340I G20
Keep the fronts and rears if they are legal, store them somewhere, when you go to trade it back in, dealers like runflats to be fitted. Otherwise they might try and knock you £1200 on the price.
03-22-2011, 05:48 AM | #4 |
175
Rep 4,302
Drives: M135i
Changed all mine when the fronts still had a fair bit of tread. I just got the fitter to take them away, such was my hatred for them!
03-22-2011, 06:13 AM | #5 |
1545
Rep 8,970
03-23-2011, 03:50 PM | #7 |
10
Rep 87
I ran 225 17 continental RFT's on the rears and Bridgestone Potenzas on the fronts for about 2000 miles - might not be factory recommended but to be honest no real ill effects unless your rear track is out but that would happen with non rfts all round. I got four non RFT's now and the car does feel much more natural.
03-24-2011, 04:35 PM | #8 |
Rep 171
For nearly a year have had RFT on rear and non RFT on fronts. No handling problems, better than when all RFT as dangerous tramlining now gone.
I do drive the car hard too. |
03-24-2011, 04:47 PM | #9 | |
LSD - No, you're not seeing things
72
Rep 3,302
Then you can do WTF you like
03-24-2011, 07:03 PM | #10 | |
25
Rep 342
At the risk of sounding extremely stupid. ....Why would it be dangerous? i thought the only difference between the tyre options is a reinforced steel wall? Is it incase you blow more than one tyre at once? Tony |
03-25-2011, 10:44 AM | #12 | |
21
Rep 482
the car wont respond as you would expect it to when turning etc, hence making it dangerous. |
03-25-2011, 11:24 AM | #13 |
112
Rep 4,021
When I first test drove my car it had new non run flat on the front. They were replaced with run flats before sale.
The front end did seem smoother and you could feel the front was a little softer too, but still the similar grip levels and equally predictable. In no way did I feel the car felt unstable though. I can't see to much flex coming through 30/35 series 19 inch tyres. |
03-29-2011, 04:38 PM | #14 |
Rep 42
My fronts are coming to the end of their life, i am getting rid of the run flats and looking at a full set of either Falken 452's or Toyo Proxes T1's any recommendations.
Thanks |
03-29-2011, 05:11 PM | #15 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
From my POV it's not reccomended but I wouldn't have any reservations in running RFT's with non RFT's - obviously same type of tyre across each axle though.
03-30-2011, 12:20 AM | #16 |
33
Rep 445
03-30-2011, 02:32 AM | #17 |
Squadron Leader (Ret'd)
25
Rep 627
You may not think it has improved - but if you had an accident and 'handling' was an issue, you can be sure that your insurance company and the police may see it differently. Your choice and your risk.
03-30-2011, 08:52 AM | #18 | |
Rep 171
On previous cars i've noticed a bigger differnce when have say new rears (as replaced old ones) and part worn fronts. Lot of mis-information on these forums from people who've never mixed but seem certain it's dangerous. I've done it in the real world for a year, it's perfectly safe, RFT and non RFT are NOT fundamentally different tyres like say cross-ply & radials usto be. They just have a stiffer side wall. Anyway just my opinion, each to their own. |
06-09-2011, 01:27 PM | #19 |
Rep 154
Drives: 2006 e90
Guys i've worked for Michelin for 22 years and as far as run flats are concerned Michelin are far superior, anything else is false econonmy,they will last loads longer,grip better,all round safer tyre,even better in the snow(with a 3x2 slab in the boot) And if you have any problems with the tyre michelin will come out to you and replace free of charge(if it's a manufacturing fault) Oh and it's bad practice to mix RFT and non RFT. Like mixing radial with the old cross thread, it is legal as long as you have the legal depth,just not a good idea..Hope this helps...Btw i get my tyres for free :-)
06-09-2011, 02:00 PM | #20 |
268
Rep 9,915
Drives: VW T5
Can I be your special friend?
