2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Installation of subwoofer in trunk
      03-17-2011, 06:54 AM   #1
drknisbet
Drives: f10 528i
Hey guys. I have a F10 528i and i was wondering has anyone installed an after market subwoofer in the trunk. I have the upgraded system with the subs under the front seats, but find in really lacks a nice low end base sound. I actually already purchased an Alpine amp with 2 10" subs but now have second thoughts. Any one have a DIY for installations??
      03-20-2011, 04:33 PM   #2
bpon89
Drives: 2011 535i Msport
I agree on the lack of low end bass sound!
      04-06-2011, 03:47 PM   #3
KRUZNM3
191
Drives: F80 M3
id love to know how others (if any?) are doing the wiring? I would love to add a little more bass as well
      04-07-2011, 12:18 PM   #4
grimlock
716
Drives: F10 N52B30@255PS
i agree, i have the hifi (middle) system and extra low end thump would be a good bonus, i imagine it cant be hard as an add-on, something to do when you have a little extra time
      04-08-2011, 03:41 PM   #5
Rochdale Pioneers
Rochdale Pioneers's Avatar
23
Drives: F10 520d SE
Are there no subs under the seats on the standard audio system? My poverty spec E91 has them albeit without the amp needed to properly power them
      04-10-2011, 01:09 PM   #6
grimlock
716
Ok, im going to hook up my home use 100w Mirage sub which is hanging around collecting dust, with this for power:
http://cgi.ebay.com.hk/Car-12V-24V-D...item3f07c4e185
The only thing left is where/how to steal the signal from.. anyone know?
Gonna take some work looking up the audio system, I just need the main signal, the sub has the cutoff. May have to find where the audio unit is, take it apart and should be there.
Just going to try this to see how it sounds with the sub, I anticipate it should be pretty sufficient, and give good tight bass.
But might not want to go with this for a long term solution, the thing weighs 26lbs! But worth a try for 4 bucks.
      05-11-2011, 02:48 PM   #7
simon530d GT
Drives: 530d GT
Find the signal into one of the larger speakers, that will contain the sub signal too.
Solder in an extra lead to the new sub amp.
Get a signal reduction kit to take speaker pwr and convert this to phono.
Plug phono into amp.
Getting good pwr to the amp is prob harder, you'l need a good supply, don't suppose the battery is nearby ??????
      05-12-2011, 12:28 PM   #8
grimlock
716
Thanks for the advice, Simon530d.
The battery is in the trunk, which is where Ill put the sub.. if I get the power through the cig lighter will be no good? Its fused at 20A@12V..the DC->AC converter I plan to run will max out far below that, perhaps 100W max steady.. ill try the filtered 12V and 13.8v direct
The first converter I order above turned out to be a piece of crap so Im going to invest a little more for a better one..
I'll need to spend so time figuring out how to remove the various trim pieces..
The sub is already amped, just runs on AC(its a home sub).. so I don't need to convert the signal to phono right?
      05-13-2011, 01:17 PM   #9
simon530d GT
Drives: 530d GT
Sorry, noooooh dat won't work at al
U need a 12 v car amp 500W or so dep on your taste
Bass enclosure & speaker
Some amps will have an inbuild sub filter
The power needs for the amp are BIG so forget the cig plug
Decent 50+ amp wire straight from the battery, fuse always nice
Your local car hifi shop should help you out
      08-04-2011, 10:08 PM   #10
650silverbullet
Drives: F10 535i Xdrive
Subwoofers in trunk of F10
Hello All, I found this picture on another thread but can't relocate it ...sorry. But I did save a picture of the final work completed. I thought it was a freakin impressive job. The owner didn't do the work and didn't really have the know how to explain the work he had done, but as I said before this looks amazing.
      08-05-2011, 07:31 PM   #11
PhiDeltBeers
96
Drives: SEVERAL
I installed a 12" jl audio last week. Pretty simply really and can be done in an evening. If you guys having already figures this out let me know. The hardest part is tearing the trunk out.
2019 RANGE ROVER SPORT SUPERCHARGED; 2023 JEEP WRANGLER RUBICON 4XE
2022 AUDI R8 PERFORMANCE RWD; 2023 BMW M3 XDRIVE; 2017 MERCEDES G550; 2023 CORVETTE Z06 (ORDERED)
      08-05-2011, 07:36 PM   #12
PhiDeltBeers
96
Drives: SEVERAL
Originally Posted by PhiDeltBeers
Nothing real special on the sub install, but it's real clean. It's a 12" JL Audio W3 with a 500.1 JL amp attached to the back of the box. I had this in my 335i, but never put in in my GT-R. If you're going to do an install, I can lead you to a good thread that tells you what wires to tap, etc...
      08-21-2011, 02:46 PM   #13
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
216
Drives: 06' E90 330, 20' F97 X3m
2006 330i SPORT  [7.34]
Looks clean. Where did you tap your signals from?
LIVE FAST..DRIVE FASTER!!
      08-21-2011, 03:59 PM   #14
PhiDeltBeers
96
Drives: SEVERAL
Signals are tapped from the speaker wires coming out of the Harmon amp. It's easy to tell which ones to tap because they are a lower gauge than the rest. A lot of people were saying a pac trunk Loc wouldn't work with this stereo, but they have since been proven wrong. Sound is perfect.
      08-21-2011, 05:40 PM   #15
Sonnie
Bama Hillbilly
Drives: 2011 BMW 528i
You would want to tap into the sub out speaker line and use something like the AudioControl LC2i to convert the speaker level to line level. This also will help compensate for the roll-off below 60Hz that is inherent in the system. Otherwise, you probably will not gain very much low end response.
      12-13-2011, 07:35 AM   #16
Flex33
Drives: 2011 BMW 535I
I Just Had Mine Installed , I Watched Them Do It The Battery Is In The Trunk So He Ran The Power And Ground For The Amp Right There , In The Left Panel In The Trunk Is Where The Factory Amp Is,he Tapped Into Those Wires And Got The Rca Signal,the He Tapped Into The Fuse Box In The Trunk On The Right Panel And Got The Remote Power For The Amp, I Got This Installed In My 2011 Gt535i, U Will Need A Test Light,and A Small Speaker To Test Wires For The Rca, I Forgot What Color The Wires Are,but I Think They Might Be The Thick Blue Wire With Red Line.hopes This Helps Out.
      06-13-2019, 01:37 PM   #17
pyu
Drives: e36 328i 6 speed gearbox
I just bought a subwoofer for my f10. Does somebody know from what fuse from the trunk should I take the wire for the Remote of the amplifier?
      06-13-2019, 09:01 PM   #18
550bye
550bye's Avatar
1390
Drives: 2011 550i
2011 BMW 550i  [5.67]
I tied mine into the rear cigarette lighter, but I will check tonight and send you photos of my install tomorrow. Are you going with a LOC or just straight hardwire into your stock wires? I can try and send you pics of a DIY if needed, let me know what you have and need. I am running a 2000w amp, 2 Rockford Fosgate 12" P3 subs, I went with a LOC and fuse disto block and breaker style fuse for power.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      09-09-2019, 10:58 AM   #19
etnsandman
82
Drives: 2015 M5 Competition
I used a harness from here: https://technicpnp.com/ to get signal and mounted a 15" free air subwoofer in my ski pass thru just like I did on my E60. Works great and no sub box steal trunk space.
5post
