The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Enable EfficientDynamics (Shift Indicator) on 6MT
      03-12-2011, 10:23 PM   #1
Toad335
32
Drives: LCI 335i
Thanks to NiVeDh:
This feature is for 6MT cars only. It basically tells you when to upshift and downshift and to which gear for maximum fuel efficiency.
It normally suggests upshifts at very low RPMs (~2000). It works well.
Once coded, it can be enabled/disabled through the OBC by pressing the BC button the indicator stalk until the instrument cluster goes to the blank screen (not displaying anything such as mpg, range, etc.). Once there, holding down the BC button for around 5 seconds toggles the feature on or off.
Here's a video:
Here's what to code...
Module: KOMBI
SP_ANZEIGE -> aktiv
SCHALT_PKT_BC -> aktiv
Enjoy.
      03-13-2011, 01:34 AM   #2
scooby9
scooby9's Avatar
61
Drives: 2007 E90 BMW 335xi
VERY nice find! Thanks for sharing this!
2007 BMW 335xi 6MT TiAg
      03-13-2011, 03:07 AM   #3
2moor
2moor's Avatar
106
Drives: E92 M3
2013 BMW M3  [9.50]
is there a way to code the actual number gear the car is in for MT? it seems pointless, but it'll look cool.
Current - '17 F80 M3 Alpine White/Carbonstructure Anthracite DCT
Previous - '13 E92 M3 Jet Black/Black Novillo DCT
Previous - '07 E92 328i Titanium Silver/Coral Red MT
      03-13-2011, 02:13 PM   #4
Toad335
32
Drives: LCI 335i
Any idea what these are about?
KOMBI:
SHIFTLIGHTS
wert_01
SHIFTLIGHTS_1
wert_01
SHIFTLIGHTS_2
wert_01
SHIFTLIGHTS_3
wert_01
SHIFTLIGHTS_4
wert_01
      03-13-2011, 02:14 PM   #5
Toad335
32
Drives: LCI 335i
A previous post says that the car doesn't have seperate sensors for each gear, so I'm thinking not. It only knows if it's in neutral or not.
      03-13-2011, 02:38 PM   #6
DJKhan85
DJKhan85's Avatar
Trinidad_and_tobago
24
Drives: 2011 4dr 6mt Golf GTI
Is coding something that can be done by me in my driveway with a BavTool?
EDIT: Nevermind...I didn't even realize there was a coding section
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD:
08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD
      03-14-2011, 11:08 AM   #7
Kalud
Kalud's Avatar
24
Drives: e92 335i
KOMBI:
SHIFTLIGHTS
wert_01
SHIFTLIGHTS_1
wert_01
SHIFTLIGHTS_2
wert_01
SHIFTLIGHTS_3
wert_01
SHIFTLIGHTS_4
wert_01
Good find, I guess we need to simply activate it with:`
Code:
MMI_ENA_SHIFTLIGHTS
	nicht_aktiv
I need to make a small change in my KOMBI so I will try later today or tomorrow.
      03-18-2011, 02:40 PM   #8
Kalud
Kalud's Avatar
24
Drives: e92 335i
Code:
MMI_ENA_SHIFTLIGHTS
	nicht_aktiv
Follow-up, tested this one... Does nothing that I can find. But I havent played with the SHIFTLIGHTS, SHIFTLIGHTS_1, SHIFTLIGHTS_2, SHIFTLIGHTS_3, SHIFTLIGHTS_4. (yet)
      03-30-2011, 01:02 PM   #9
allerena
25
Drives: 435i xDrive
My best guess is that those are for the steering wheel that has lights (///M).
sorry I meant to say the instrument cluster that has lights over the revs.
      04-10-2011, 12:50 PM   #10
Nr!qUe
Nr!qUe's Avatar
70
Drives: 2009 E90 LCI 328i 6MT
EDIT: the triangle appear on my dash but they don't do anything
My buddy said that it might be my SSK. I didnt believe that to be the reason but i cannot think of any other reason why
2009 BMW E90 328i | Xenons | MT | Space Gray | Beige-ette | CF Fabric Trim | iPod/USB | 20% Tints | Euro-Plate | Rear Fog Switch Lego Mod | Painted Reflectors | Performance Short-shift Kit | Style 197 Wheels | OEM Sport Suspension |
      05-13-2011, 09:17 AM   #11
excel
Drives: 328i
I have the same problem and I have a 328i as well. People on the 'other' forum are saying the same thing. If anyone with a 6MT N52 car are able to get the arrows to work please let us know how you did it.
      05-17-2015, 04:25 PM   #12
Illoosive
Drives: E92 328i 6MT
Don't want to bumpan old thread but ccouldn'tfind an anewer to why the 6mt once coded the arrows don't do anything.
      05-18-2015, 12:12 PM   #13
josehon
josehon's Avatar
17
Drives: 2008 Apline White 328i E93 6MT
When I use NCSDummy to check the option, it shows the option is available on N52 engine with ACEA_CO2, which mean you need 1CB (ACEA / CO2 SCOPE) in your VO.
I own a 2008 328 6MT, I try to enable the indicator, but no luck. Same result as everyone that has 328.
And when I check my VO, I don't have the 1CB option. If anyone has a 335 6MT, you can check if your VO has this option. If you do, that will confirm that 328 has a missing component, so it cannot be done.
You can use the following link to check your VO.
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
      05-18-2015, 12:43 PM   #14
Illoosive
I don't have it either assuming I'm looking for the 1CB code on the VO
      05-18-2015, 02:06 PM   #15
david in germany
729
Drives: 118i, 335i and 328i
I activated this in my 09 335i with bmwhat. I tried to do it in my wife's 11 328i and it showed the up and down triangles but not the gear change info.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      05-18-2015, 03:23 PM   #16
josehon
josehon's Avatar
17
Hi David, can you check your VO on your 335i if it contains 1CB. Thanks.
      05-18-2015, 03:48 PM   #17
Illoosive
S1CBA right... I'll have my friend also check his 1 series because he coded his and was able to get the arrows to actually do something
      01-27-2017, 06:12 AM   #18
bfleming
96
Drives: Merc, VW, Porsche, Suzuki
There are a couple of factors here
- Manual cars with start-stop capability have a neutral position switch on the top side of the gearbox
- The gear ratios fitted to a specific car are part of the ECU programming. So when it's in any gear, it looks at the speed & rpm & says 'I'm in gear x'. This is how the ECU then tells the driver (via the instruments) that there is a better gear to be in!
- If the ratios don't match, e.g. you've had a gearbox or rear diff change which are not like-for-like, the ECU won't be able to calculate what gear it's in. It will not relearn the ratios.
- If the ratios don't match, your gearchange indicator (german: Schaltpunktanzeige) will not work.
- If the ratios don't match, your cruise control will not work.
It is feasible for someone to reprogramme the ECU with the new ratios, but this is NOT a simple coding adaptation using NCS. If you have a new (different) gearbox in there, reprogramme using the new ratios. If you have a new diff, you will need to work out what the relative gearbox ratios are as there is no parameter for the rear diff as far as I'm aware.
